engine shut down while driving
Old Jun 1, 2019 | 05:39 PM
AllaboutMPG's Avatar
AllaboutMPG
you replaced the IPR for this break down or at an earlier time?
You could check the bolt on the front of the HPOP and make sure it didn't come loose since HPOP was recently replaced.
Could Dead head the HPOP line going to right head to make sure you don't have a massive leak on that side or do a Cody test.
Just oozing out of ICP hole sure seems like HPOP isn't making any pressure
Old Jun 1, 2019 | 06:37 PM
Walleye Hunter's Avatar
Walleye Hunter
No oil getting to the HPOP, the HPOP itself and...just maybe a bad IPR. Did you use OEM on the new IPR?
Old Jun 2, 2019 | 10:29 AM
HD Rider's Avatar
HD Rider
As already stated, free to check that the bolt on the HPOP drive gear is still tight.
Do you still have your old IPR and was it still working? If so swap it in.
Hate to say it but it's sounds like HPOP failed.
Loxley
16
Oct 25, 2016 10:19 AM
Stewart_H
30
Feb 18, 2016 09:24 PM
jayc3169
Aug 19, 2012 11:40 AM
mercman86
13
Dec 1, 2009 01:35 AM
Gene Jameson
May 4, 2006 10:49 PM
