Getting Horn to Work
1963/64 Thunderbird and the alternators introduced in 1965 were Auto-Lite's as FoMoCo owned Auto-Lite back then.
The original 'point type' alternator regulator part number was: C3SZ-10316-A (C3SZ = 1963 Thunderbird).
Ford updated the part number several times, the last number was D4TZ-10316-A .. Then in 1982, it was replaced by E2PZ-10316-A an electronic regulator that had MOTORCRAFT stamped on its flat cover.
Ford updated the part number in 1990: FOPZ-10316-A
https://www.painlessperformance.com/Manuals/30831.pdf
My ‘63 had generator and regulator when I got it but now has a three wire GM alternator.
I acquired a horn relay and brush from Dennis Carpenter. Nice fast shipping, arrived the second day.
Question #1: There are three wires that go to the relay; one from positive battery power, one to the horn, and one to the horn button. Which wire goes on which relay terminal?
The left terminal is marked as #1, middle is #3, right is #5.
Question #2: There are six wires connected to the turn signal switch. One of them shows 12 volts when grounded to the top of the steering column. This, I assume, is the horn wire. Is that correct? I need to know to trace it out under the hood and connect it to the relay. On a related note, I assume six wires is the right number? I'm not missing any?
The blue one second from the top is the one that carries 12 volts with the key on.
Question #3: My horn brush looks like this. Did I get the right part? It's slightly too big to fit in the previously-discussed-by-ND bushing under the horn ring. I can drill the bushing out a bit, but ..... wrong part or just crummy part?
Question #4: How, exactly, does the 12V current get from the turn signal switch up to the contact plate directly underneath the horn ring (that grounds to the top of the column)? I can trace it backwards from that plate through the horn brush and to the plate that mounts to the bottom of the steering wheel, but then where? I want to be able to check for continuity and make sure all the components are present, clean, etc. Here's an image of the inside of the column, underneath the wheel. Does everything seem in order? I know on other threads people have talked about another brush, somewhere under the wheel (it's a bit fuzzy what exactly they're discussing). Is that applicable to a 1961 F250 2wd? Is it missing?
Thanks. It's a long-winded post, but y'all are lifesavers on getting this figured out. Hopefully this will help somebody else with a similar problem sometime.
Question #4: How, exactly, does the 12V current get from the turn signal switch up to the contact plate directly underneath the horn ring (that grounds to the top of the column)? ... I know on other threads people have talked about another brush, somewhere under the wheel (it's a bit fuzzy what exactly they're discussing). Is that applicable to a 1961 F250 2wd? Is it missing?
Wherever the bottom of the brush contacts basically, should show continuity to the horn wire bullet connector at the engine side of the firewall. I would pull the steering wheel off my F100 to show you how it is setup, but it wouldn't really do any good since it's different design, and I've had quite enough of pulling and reinstalling the steering wheel, had an intermittent that kicked my *** for a little while. It's always the stupid stuff that is aggravating. Pull an engine, re-install? No problem! Horn inop? Problem. lol
It’s still sitting in the yard.
Should be able to sound the horn from the relay itself, mounted on the apron, through test light or jumper wire to ground. Horn and brakes are always "hot".
Use a voltmeter to verify the blue wire with yellow stripe has 12 volts. It should be hot at all times if the relay is working. With the steering wheel removed the lower brush should have 12 volts. When you install the steering wheel, the brush in the wheel should also have 12 volts. If you jumper from the upper steering wheel brush to the steering shaft, the horn should sound. If you have 12 volts on the brush but the horn doesn't sound, then you need to ground the steering shaft at the rag joint.
