Turbo failure?
Old Oct 3, 2003 | 10:17 PM
2Wise4aGM's Avatar
2Wise4aGM
Turbo failure?
My buddy has a 2000 f350 powerstroke that has developed an oil leak problem. He says the intercooler tubes(connecting hoses) have always been a little oily, but the one on the pass. side (right next to the cooler) is now leaving a puddle. I told him that I tought the only way oil could get in there is from the turbo. Anyone else have any ideas, before he tears into this?
Thanks
Old Oct 3, 2003 | 10:21 PM
allisfarm's Avatar
allisfarm
clean it,make sure clamps are tight and verify that it's leaking there. where is the oil puddle at.
Old Oct 3, 2003 | 10:36 PM
2Wise4aGM's Avatar
2Wise4aGM
What would it matted if the clamps were tight? There still shouldnt be oil in there! I am sure that is where its coming from. You can see it drip from there after you drive it.
Old Oct 3, 2003 | 10:46 PM
allisfarm's Avatar
allisfarm
it is normal to have an oil residue or film on the cooler tubes,but it is not normal to be leaking. my passenger side tube is always dirtier than the drivers side cooler tube.
Old Oct 3, 2003 | 10:55 PM
allisfarm's Avatar
allisfarm
if you or your buddy get the powerstroke registry magazine,the latest issue has a letter in the back where doug lewis explains why the tubes are dirty and how much oil can be seen. has to do with the crankcase ventalation.
Old Oct 4, 2003 | 01:11 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It is the crankcase vent. On top of the driver side valvecover you can see the vent, and the 3/4" hose that connects it to the intake ducting. Pull all the intake ducting to the turbo off and you will be amazed by the amount of oil blowing in there.
Pulling the boots and cleaning them will help for a while, but the only way to actually stop it is to reroute the vent.
Old Oct 4, 2003 | 01:19 AM
cookie88's Avatar
cookie88
FTE Emeritus
Oh, and normally when a turbo fails it will let go on the exhaust side first. Any billowing clouds of smoke out the tailpipe or oil dripping from it? Generally this is preceeded by a few days/weeks of abnormally loud turbo whine.
Not saying he hasn't blown the turbo, just that it's not too likely given your description.
Old Oct 4, 2003 | 09:04 PM
2Wise4aGM's Avatar
2Wise4aGM
Thanks for the replies. I will check it out and let you know what we find.
Butch(OH)
20
Nov 14, 2016 08:49 PM
jeffl1107
Large Truck
Aug 9, 2012 08:48 AM
RCrawler
Mar 30, 2012 11:01 PM
Dr. Johnson
Dec 30, 2011 02:26 PM
2 stroke man
Aug 29, 2009 07:29 PM
