How many keys do you have?
Old May 28, 2019 | 05:52 PM
tractoman's Avatar
tractoman
Never thought much about it but when I got my truck, it had two keys, both work the ignition. Never tried them in the door until recently and they don't seem to work.
Did these trucks come with separate ignition and door keys? Any way to get keys form the dealer with the VIN and proof of ownership?
Thanks,
Old May 28, 2019 | 06:22 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Pretty sure late ones had one key for all. My 10/95 has only one key, I rekeyed it for cheap. I have four OE Ford keys and two off-brand spares I needed in a pinch.
No clue what it ran to rekey, maybe a C-note. That was two years back nearly.
Old May 28, 2019 | 08:30 PM
farmert's Avatar
farmert
These trucks came from the factory with 2 keys. Both worked for the ignition and door locks. My guess is that the original tumbler bit the dust, and the PO installed a new tumbler which came with new keys.
Old May 28, 2019 | 08:36 PM
ford390gashog's Avatar
ford390gashog
Really easy if you want a matching set. You can get the ignition tumbler and two door cylinders for under 80.00 and they are a matching set.
Old May 28, 2019 | 08:50 PM
85F250Diesel's Avatar
85F250Diesel
Since my truck has power locks with keyless entry, the door tumblers have seen significantly less use than the ignition tumbler. The key and ignition have worn together over the years, and the worn key has some trouble unlocking the doors sometimes. I know for a fact that it’s the right key though.
Old May 28, 2019 | 09:36 PM
tractoman's Avatar
tractoman
So I am just an idiot. Went and tried both keys again and they both work. Just needed some jiggling to get them to turn. Have keyless factory alarm and never used them.
Old May 28, 2019 | 11:21 PM
pilgrimbizket's Avatar
pilgrimbizket
I have to occasionally spray some lube into the keyhole and work the key to keep the passenger cylinder working right
Old May 29, 2019 | 06:54 AM
BuddyBarnes's Avatar
BuddyBarnes
This is what I do.
abe
Jan 3, 2016 10:47 PM
Neil_E.
Dec 30, 2008 06:50 PM
dave75
18
May 28, 2008 03:38 PM
Rick2324
Nov 21, 2005 11:06 PM
will1010
2004 - 2008 F150
Nov 4, 2003 03:31 PM
