Sponsored by: Real Truck
Weird misfire issue
Old May 28, 2019 | 09:12 AM
Scott Bishop's Avatar
Scott Bishop
Weird misfire issue
So my work truck that I drive everyday is a 2008 F-350 with the 5.4 V8. We’ve got way too much weight on it, so it honestly struggles getting up hills sometimes. Especially from a stop, gas pedal is on the floor and it accelerates rather slowly. Under these extreme load conditions, it will occasionally give a misfire code (check engine light flashes). At the same time, the AC starts blowing warmer. What in the world could cause both a misfire and warm AC? Only thing I can think is that maybe a belt is slipping on the alternator and the compressor, but there’s no “belt noise,” and I’m not even sure a slipping alternator belt would cause a misfire. Any other ideas?
Old May 28, 2019 | 12:46 PM
Chuck's First Ford's Avatar
Chuck's First Ford
computer turning OFF the AC to help the engine..
misfire
old spark plugs
overheating spark plug coil(s)
injector having an issue .. soon to fail.
Old May 28, 2019 | 02:02 PM
Scott Bishop
misfire
old spark plugs
If it’s the computer, would it really only do it in the case of a misfire? There are plenty of times when I have no power because of the load, but it’s not misfiring.
Old May 28, 2019 | 02:24 PM
Fefanatic's Avatar
Fefanatic
If the check engine light is flashing then it is misfiring. It may set the code for which cylinder is the culprit. As far as ac? Most compressors will cut out on low intake vacuum and unter sever load with throttle on floor it would have low manifold vacuum. Have someone run a cylinder contribution test and see if a cylinder is not pulling its weight.
Old May 28, 2019 | 04:50 PM
MM8's Avatar
MM8
Your truck has gone into "Limp Mode" in order to protect the engine or transmission - that's why the AC is cutting out in conjunction with the performance issue. If things get bad enough, the computer can start shutting down cylinders and pump air through them, or only engage second gear in the transmission, in order to protect the vehicle.
Years ago the computers in vehicles would completely shut the engine off as a means of protection. The manufacturers realized it may be hazardous to shut the engine down while a vehicle is on the highway, so they invented Limp Mode as a substitute. If your vehicle goes into limp mode, it needs to be pulled off of the highway as soon as possible, and towed in for repairs.
Old May 28, 2019 | 05:46 PM
Scott Bishop
That’s interesting. Is there no warning or anything that it’s in limp mode? I have a check engine light obviously, because of the misfire, but the only code it gives is “random/multiple cylinder misfire” and “cylinder 3 misfire.” For the record, we’ve changed plugs and coils on every cylinder twice.
Old May 28, 2019 | 07:16 PM
Fefanatic's Avatar
Fefanatic
Random multiple misfire can and most likely will be caused by low fuel. It will misfire if it can't get enough fuel to burn properly.
Old May 28, 2019 | 08:22 PM
MM8's Avatar
MM8
If the computer senses the engine or transmission is getting too hot, or not maintaining correct fluid/oil pressure, and a whole host of other things, can put the vehicle in limp mode.
The sensors which operate your gauges are typically not the sensors that signal the engine control module. You can have a problem and all of your gauges read fine.
AC cutting out and loss of power are typical when the vehicle goes into limp mode.
hortonjoew
13
Oct 11, 2016 10:53 AM
mattocs
Escape & Escape Hybrid
Oct 3, 2012 02:10 PM
stupidjet
Apr 12, 2010 10:17 PM
XXL Supreme
Mar 9, 2007 12:17 PM
midapo
Aug 22, 2006 03:38 PM
