Injector Questions
Old May 27, 2019 | 02:04 PM
big315's Avatar
big315
Injector Questions
I have a 2007 Ford F-350 with 220,000 miles. I think I have an injector going bad, because when the truck is cold, it feels like it has a miss in it. When it gets warm, for the most part it goes away and runs fine. You guys on this site have never let me down, so does anybody have any ideas?
Thanks,
John in Mobile, AL
Old May 27, 2019 | 02:42 PM
xcrsp440's Avatar
xcrsp440
Get an obd2 wireless adapter and the Forscan app. Look for codes check for misfires.
Use Ford injectors. Autonation in White Bear Lake has them around $180.
Old May 27, 2019 | 08:53 PM
Ford.Dude's Avatar
Ford.Dude
Check the ficm volts? From what I hear, anything 46 and below is a troubled ficm.
Fuel pressure shouldn't be below 45 psi.
Old Jun 10, 2019 | 10:25 PM
big315's Avatar
big315
I bought the ArchOil Fuel System cleaner and the oil additive. I'll be damned it worked. I am just thrilled!!
ArchOil makes some great products. !
Old Jun 12, 2019 | 12:16 PM
High_HP's Avatar
High_HP
For me a new FICM at 160k fixed my stiction. The additives just band aid the problem but don't fix it. Good luck!
Old Jun 13, 2019 | 10:47 AM
navistarnut's Avatar
navistarnut
Sounds to me like a classic case of stiction that was cured with Archoil.
You are one of many happy customers, myself included.
As HP mentioned, it's not permanent but may very well last for years if you keep running it.
Old Jun 15, 2019 | 10:50 AM
IHateCommieCars's Avatar
IHateCommieCars
Definitely confirm your fuel pressure is good though. It'll burn up injectors if not.
Old Jun 15, 2019 | 08:02 PM
F350 1990's Avatar
F350 1990
Product is solid, albeit overpriced.
scameron
Nov 6, 2022 02:14 AM
bismic
Jul 12, 2016 01:11 PM
crankytrucker
Aug 3, 2010 11:08 AM
Ford Yankee
Nov 21, 2007 06:17 PM
