429 4spd
Old Oct 3, 2003 | 09:11 PM
plowboy81's Avatar
plowboy81
429 4spd
I have a 1979 F-250 with a 4spd and an I6. I have a 429cj to put in it. Does anyone else have the same setup and how did you do it. I know a true 429 bellhousing will work, but I can't find one. I also know I can use a 351m/400 bellhousing with a 1/2" spacer. Thanks for any information.
Old Oct 3, 2003 | 11:58 PM
68back's Avatar
68back
The bellhousing off a 460 will work & you shouldn't need any shims.
Upper Case edited out by FTE
Old Oct 5, 2003 | 09:03 PM
plowboy81's Avatar
plowboy81
Ford didn't mate the 460 with a straight drive until 1980 and they were all hydrolic. Pre-1980 460 motors were mated with automatics.
Old Oct 5, 2003 | 09:46 PM
neverenough's Avatar
neverenough
What tranny do you have? There are 2 different 435's and a couple of different T-18's. The difference in the 435's is the length of the input shaft. Using a spacer depends on which input shaft you have. My 429 dropped right in where a 400 was.
Old Oct 5, 2003 | 10:32 PM
plowboy81's Avatar
plowboy81
I have the NP435 in mine.
15
Dec 29, 2011 11:07 AM
swolh
19
May 17, 2010 10:01 AM
96-5spd302
Mar 26, 2004 07:37 PM
67 428 Fairlane Ranchero
Mar 8, 2003 08:41 AM
74crwcb429hibPS4spd
Jan 7, 2003 01:28 PM
