High Idle Problem
Old Oct 3, 2003 | 08:18 PM
brrossi's Avatar
brrossi
High Idle Problem
Could an out of range or missadjusted TPS cause a high idle (1500 and higher RPM) on an 88 5.0 F-150? The only code I get from the EEC is for this.
Old Oct 4, 2003 | 12:10 PM
LxMan1's Avatar
LxMan1
Yes it is possible. If it is too far advanced, it will advance the timing and injector pulse.
I would remove and clean the IAC first.
Jimmy
Old Oct 7, 2003 | 10:47 PM
neverenough's Avatar
neverenough
Check the voltage it is puting out. It should be .5-1.0 volts with a closed throttle. As the throttle is opened the reading should increase smoothly to 4-5 volts at WOT. If it works good but the reading is high at Idle it can be adjusted down by loosening the screws and moving it.
Old Oct 8, 2003 | 04:16 PM
wolfen's Avatar
wolfen
Howdy;
Question: The TPS is adjustable by loostening the 2 screws and rotating it?
When it is removed, there seems to be a rotating "spring like action"!
When reinstalling it, how do I know that I have set it in it's proper position on a 2.3L EFI~4banger?
I also have the high idleing, but never over 1500rpm and it does decrease after about 10 seconds. While this is going my CEL is lit!
____________________________________________
Take a walk on the wild side + you'll find me there!!
The Brain Is Always On The Move
_______________________________________________
My Beastie:
90 Ranger 2.3L EFI 2wd Mazda < with many new parts!
Old Oct 8, 2003 | 10:58 PM
LxMan1's Avatar
LxMan1
The output voltage should be no more than 1.0 volts at idle position.
It is normal to idle up for a second when first started, then it will come down to around 750 when it settles.
If it is staying too long, I would look into the IAC for sticking or being sluggish. A good cleaning may help.
Jimmy
Old Oct 9, 2003 | 09:57 AM
wolfen's Avatar
wolfen
Hi lxman1;
Thank you for your response!
Dissassembled, inspected + cleaned IAC valve< (Is this also known as an Air Bypass Valve?) Should the internal mechanism inside slide in + out tightly or have slack? My idle is high @ start up + any time but it does settle to roughly 8-900 rpm within 5-8sec.'s and stays there until I'm underway then when I approach a stop signal, I depress my clutch + the idle is @ 1500 then within 5 sec.'s drops to 8-900, never any lower. And also having disassembled the TPS to inspect, clean + reinstall it, I found there is a white plastic piece in it that rotates, under tension, and hooks up to the throttle plate thus regulating it's movement. How do I know it was reinstalled correctly by check the output voltage like you have stated?
COME - BACK!
My Beastie:
Old Oct 9, 2003 | 12:02 PM
LxMan1's Avatar
LxMan1
You shouldn't move the plunger in the IAC at all, it probably has stripped gears on the motor. I would get a new one.
Jimmy
Old Oct 9, 2003 | 12:23 PM
wolfen's Avatar
wolfen
Hi again lxman1;
Thank you for your multiple responses! Will check into pricing of this sensor and definately not @ a dealership!!
FTE IS GREAT! FTE FOREVER!!
My Beastie:
Old Oct 9, 2003 | 12:30 PM
brrossi's Avatar
brrossi
I checked the TPS voltage at idle. It was at 1.27 volts. However, I decided to check the timing. It was at 5 before TDC. I reset the timing to 10 BTD. Also did a deflection test on the timing chain it is tight. After reseting the timing the voltage on the TPS dropped to 1.0 volts and operates smoothly. I have yet to clear the old codes and see if the TPS code comes up again. I still suspect a marginal MAP sensor as I noticed the exguast pipe is black and sooty. So far the suggestions I have gotten in this forum have helped in trying to track the problem down. when I finaly hit on the problem I will share it with all. Thanks
The weird thing is, is that since it warmed up to 80 degrees out side my problem has not been as bad.
Old Oct 9, 2003 | 12:41 PM
wolfen's Avatar
wolfen
Hi brrossi;
Unhook your battery for 20 min. to clear your codes! This process is one of the processes that are used! I have EFI! I assume you have a distributor?
COME - BACK!
My Beastie:
Old Oct 14, 2003 | 11:30 AM
brrossi's Avatar
brrossi
Just to keep you up to date on my quest to repair my high idle problem. After 4 days of running fine it finaly started the high idle routine again. This time I was armed with a digital volt meter and checked the output voltage on the TPS. It had jumped from 1.0 volts to 2.47! The throttle is still against the stop. I guess I may have a faulty TPS. (the weather changed also, from 70's to 50's) I guess I will have to replace it.
Anyone agree with this?
Old Oct 14, 2003 | 02:02 PM
LxMan1's Avatar
LxMan1
Sounds like the culprit to me.
Jimmy
Old Oct 17, 2003 | 02:52 PM
brrossi's Avatar
brrossi
Figured I would update you all on the idle problem. It has been solved with a new TBS. Thank you all for your input on my problem, the info on the TBS voltage output helped me track down the problem.
Old Oct 18, 2003 | 06:11 PM
LxMan1's Avatar
LxMan1
Glad we could help.
Jimmy
Gerryatrics
1997 - 2003 F150
19
Mar 30, 2014 06:11 PM
tneyman
Jul 23, 2007 02:22 PM
FORDWRENCHHEAD
Jan 7, 2003 02:52 PM
georgedavila
1978 - 1996 Big Bronco
Sep 18, 2001 07:54 PM
jopey
Oct 11, 2000 01:50 PM
