Sponsored by: Real Truck
Noise when turning left!
Old May 25, 2019 | 06:31 PM
James2001F250's Avatar
James2001F250
Today my 2001 F250 7.3 4x4 started making a sound whenever I turn left. I purchased it new & it only has 132k miles on it. It isn't a constant whirring sound like a normal bearing would make but it sounds like it's making a scrub scrub scrub scrub sound & the faster I'm going into the turn the faster the scrub sound is. Any suggestions or recommendations as to what this might be? Thanks
Old May 25, 2019 | 10:45 PM
Djosbun's Avatar
Djosbun
Sounds like a wheel bearing to me. I have heard different sounds from different bad wheel bearings.
I’d at least jack up the corner and inspect it thoroughly.
— Dave
Old May 29, 2019 | 08:37 AM
James2001F250
— Dave
Thanks Dave. I did jack it up & spun the wheel with it turned to the left but no sound. Guess I'll take it in & have it checked out.
Old May 29, 2019 | 03:02 PM
brian42's Avatar
brian42
Veteran: Navy
Just spitballin' but a sound that changes with speed (rotation) makes me lean towards hub as Djosbun mentioned. These unitized wheel hubs are stout but not the beefiest things around. There's an inner needle bearing that can't be lubed with the hub installed.
If it's scrubbing when you turn left then your most likely culprit is the right (passenger's) side hub since it gets way more loading when your turn left.
Old Jun 3, 2019 | 12:14 AM
darkjedi351's Avatar
darkjedi351
the unit bearing would be my guess. they're hit and miss for longevity. I got 190K out of mine
Old Jun 3, 2019 | 09:57 AM
James2001F250
Thanks for the input, as it turns out the wheel bearings were bad on the left & the right!
Old Jun 3, 2019 | 08:11 PM
Djosbun's Avatar
Djosbun
Glad to hear that you have your issue resolved, James.
— Dave
Old Jun 4, 2019 | 09:13 AM
James2001F250
Thanks for everyone's input!
Old Jun 4, 2019 | 11:55 PM
darkjedi351
just a fyi, riffraff makes a bearing grease adapter tool. it bolts in place of the wheel speed sensor for greasing and is then removed. check it out, it may help with extending the life of your new bearings
forrest-38
Oct 31, 2018 07:41 PM
hambass
May 9, 2017 07:28 PM
niceguy4872
Aug 14, 2014 06:12 PM
browntown3
Sep 24, 2009 05:38 AM
misterfisher
Mar 23, 2007 01:01 AM
