rotella elc nf
My current thinking is that the Nitrite Free version is ok.
I like cbonet's post and SmackDaddy's post (#42 and #43) in your third link:
https://www.ford-trucks.com/forums/1...coolant-2.html
Personally I do not have any concerns over the NF formulation, but I am still anxious to hear Shell's response.
My truck is running hotter than normal since the engine work. The only thing that has changed is I added coolant return lines and installed a new Motorcraft 192 degree thermostat for the heck of it.
I suspect I need to pull the radiator out and really clean it well. There are some small bugs in the top exposed fins of my Mishimoto radiator. Yesterday I was towing my boat and was seeing 200-208 ECT and 208-215 EOT with 85-88 degree air temperatures at 70mph which is quite a bit higher than I usually see even when it’s 100 degrees or more. Kind of aggravating after all the work I’ve done. All I can think is the radiator needs a good cleaning.
AutoJim was a member on TDS and was one of the designers of the cooling system on the 6.0. He advocated cleaning the heat exchangers on a regular basis, especially when you have the radiator our. Ever since he posted that 18 years ago I’ve done that when the opportunity exists, and sometimes even when everything is still installed. It always amazes me on all the vehicles the dirty water that comes off.
I've not used that particular cleaner, but they work well.
I just did my home condenser a few weeks ago with the foamy.
I’ve even used a Dawn solution in one of my garden sprayers per AutoJim and it’s worked well. I had to chuckle at the post and video as I have the non-coated Mag cleaner hanging on the fence to do a few of the heat exchangers. My 16 year old east coast units have a lot of oxidation and I was going to try it to get off the oxide rather then go through the cost of new exchangers. I already have a new radiator.
It also should be mentioned that Sean’s often recommended Simple Green Aluminum Aircraft Cleaner also works well in this situation, although no foaming action.
shell's reply for rotella ELC NF
Your 2007 Ford F250 6.0 Diesel calls for an engine coolant that meets the Ford spec: Ford WSS-M97B51-A1. The Rotella ELC NF was not designed to meet that Ford spec. We recommend using ShellZone Multi-Vehicle Antifreeze/Coolant 50/50 -- suitable coolant for your vehicle.
Thank you for your interest in our products.
Best Regards,
Jeff Santos
Shell Technical Information
(800) 237-8645 Option 3, 1
Best Regards,
Jeff Santos
Best Regards,
Jeff Santos
Best Regards,
Jeff Santos
