Help please
Old Oct 3, 2003 | 06:44 PM
belly boat's Avatar
belly boat
Help please
I have a 2001 4.6 aoto 4x4. Twice now when leaving work in the same spot my truck wont excelerate the tranny does not shift and no revs. I pump the gas a few times and boom away she goes. Now the truck sith for 10 hours at work and its warm out. I go about 3 bolcks and round a corner to the right when the problem occurs. I get no codes and the engine is idels fine when the problem shows its ugly face. Help me PLEASE.
Old Oct 4, 2003 | 12:06 PM
LxMan1's Avatar
LxMan1
TPS sensor or a bad wire going to it?
Just a suggestion.
Jimmy
Old Oct 4, 2003 | 10:29 PM
belly boat's Avatar
belly boat
Cant see how the tps would cause that but looked good and wires are good as well.
Old Oct 5, 2003 | 01:53 PM
LxMan1's Avatar
LxMan1
The TPS tells the computer how much throttle is being used. This is one of the inputs that it uses to adjust timing, fuel curve and tranny shifting.
Also, have you checked the fuel pressure? It could be dropping out and causing it to not want to run.
Jimmy
Old Oct 5, 2003 | 05:19 PM
belly boat's Avatar
belly boat
I have not checked fuel pressure. What should it be and how do I connect and where do I connect ???/
Old Oct 5, 2003 | 10:02 PM
wmcnally's Avatar
wmcnally
I have a 2001 4.6 aoto 4x4. Twice now when leaving work in the same spot my truck wont acccelerate the tranny does not shift and no revs. I pump the gas a few times and boom away she goes. Now the truck sith for 10 hours at work and its warm out. I go about 3 bolcks and round a corner to the right when the problem occurs.
belly boat,
lxman1 is probably right. If what you mean by "in the same spot" is that the problem occurs at the same point in your drive home, it indicates a bad sensor.
When you start your engine "cold", it will run "open loop". Meaning it runs on a pre-programmed routine for A/F, timing, tranny shifts etc. When it comes up to temp the ECU "takes over" and reads the various sensors and uses this info to set the A/F etc.
If at the point you go from "open loop" to "closed loop" you have a drivability problem you can be sure it is a sensor or ECM problem.
Going by your symptoms I'd agree with lxman 1 and start with the TPS.
Good Luck,
Bill
Old Oct 6, 2003 | 04:29 PM
belly boat's Avatar
belly boat
Just checked tps it has no bad spots. Has 5v signal and when I open it up slowly it gradualy goes up to 4.84 then down with no odd dips.
Old Oct 6, 2003 | 10:26 PM
FortyFords's Avatar
FortyFords
Do you have a scanner with capture mode ?
Drive the vehicle and do a capture of all systems
then look at the data
You need to see if the tps is sending the correct info the the pcm.
Done this many times to find intermittent type problems
Did you chk the fuel pressure as suggested?
or change the fuel filter ?
Rich
Old Oct 6, 2003 | 10:40 PM
belly boat's Avatar
belly boat
Has a new fuel filter have not checked pressure. I donot have a scanner but I am getting the new microtuner not sure if it has a capture mode.. you tell me
