Wrong Axel?
Old May 24, 2019 | 11:28 AM
RenoHuskerDu's Avatar
RenoHuskerDu
Originally Posted by landman873
Ford spelled it right. the OP didn't.
Apologies to Ford's workers.
Old May 24, 2019 | 01:48 PM
T diesel's Avatar
T diesel
You’re funny! You should know your rear end.
Old May 24, 2019 | 05:06 PM
PaleRider01's Avatar
PaleRider01
Ouch!
Dudes Dudes Dudes, Stupid speech to text spelled axel wrong. OMG it did it again. I keep saying axel and it keeps spelling it axel. he he jk I did it on my laptop this am with a cof of cuppee in my hand.
I am surprised noone has made a reference to Guns and Roses. I mean C'mon.
Ok lesson learned. It is an Axle!
Still would like to know why it says wrong axle on it. I tried the locker this morning and it worked so it is an electronic locking axle. I believe it is the M275 as well. The only thing that could be wrong is it could be a 3.31 however the rpms seem to be correct and same as my 2015. Ill bring to my buddies shop and we will lift it and rotate tires and count driveshaft revolutions and determine if it is 3.55 or 3.31.
Thanks for the replies and the rips!!
All good!
Anyone that has any further info as to why that was written I'd still be anxious to know. Also my salesman said he forwarded my pics to his service manager. Not sure what he'll find out but I will share.
Thank You.
Old May 24, 2019 | 05:43 PM
RenoHuskerDu
"Jamie's Got a Gun" and "Enter Sandman" are two of my favorite songs. How does your phone even know to spell Axel? My android doesn't. Guns n Roses.
Now, wut TH are you doing with an E-locker? My 350 drw with Eaton has LS. I thought the E-locker only came on Sterling diffs. It would be a really cool locker if it worked over 2.8 mph or whatever its limit is. Or better still, if it were LS until you decide to lock it entirely. Now that would be cool.
I bet your axle was in another truck, installed by accident, and they pulled it out to put it in your truck where it belongs. We owned an assembly line ourselves until not too long ago, you'd be amazed at the errors that occur. That's why there's an entire backup shop that does nothing but fix errors made on the line.
Old May 24, 2019 | 06:01 PM
67L48's Avatar
67L48
Ugh. It’s getting even worse. The lead singer for GnR is Axl Rose, so you’re still off and a joke in that direction wouldn’t land.
Those two songs are performed by Aerosmith and Metallica, respectively. And it’s Janie, not Jamie. Hopefully it was sarcasm.
Maybe we should go back to discussing trucks.
Old May 24, 2019 | 06:04 PM
RenoHuskerDu
I'm just a Motorhead, sorry for the clumsy sarcasm
Old May 24, 2019 | 06:53 PM
Desert Don's Avatar
Desert Don
This is 2 E Z. Sterling AXLE...........12 bolts on the diff cover.....DANA M275......14 bolts on the diff cover.
Old May 24, 2019 | 11:44 PM
UGA33's Avatar
UGA33
I’m betting that axle was put in the wrong truck before it made it in yours. Once the trucks come off the line, there is an area to correct goof ups. Basically a mechanic shop. Saw em swapping out rear ends on a brand new F-350 DRW that had just come off the line. A lot of the stuff we saw in 2016 were fixes because the line didn’t have the 2017s down pat yet as they were coming down the line for the first few times. Missing bolts on running boards, etc.
Old May 25, 2019 | 07:27 AM
jimzpsd's Avatar
jimzpsd
Is there a plus or minus for having either one..........why the two different axles?
Old May 25, 2019 | 07:54 AM
UGA33's Avatar
UGA33
Dana is bigger. Increased towing capacity with it over the Sterling. Over 5,000 LBS more towing capacity.
Old May 25, 2019 | 12:23 PM
jimzpsd's Avatar
jimzpsd
Thank you, I have the Dana too
MrBlue6869
Jun 10, 2018 02:59 PM
Kirbys73F100
103
Aug 15, 2013 05:04 PM
beersy50
78
Apr 3, 2011 08:32 AM
adam83
13
Oct 28, 2009 05:24 PM
Slow
Aug 21, 2007 03:20 PM
