getting rid of ABS
getting rid of ABS
1996 E350 based RV w/7,5L E4OD ,
can I get rid of the 4 Wheel ABS ?
I switched my rear diff to a disc brakes 99 Dana70 similar to my 96 drum brake version ....
My concern : the back brakes are barely used ,
Id like to have more pressure at the back
I already took off the residual valve on the master cylinder ( replaced with a direct fitting -no obstruction ) ' I tought id get more pressure to the rear wheels brakes , nope !
or would anyone know how to solve this issue ?
I tow a Jeep quitre often , I need more back brakes ....
I have pondered this myself, for my 96. I am thinking the thing to do is to buy some brake line and fittings, and bypass the ABS pump. It's located along the frame rail on the driver's side. If you crawl under right where the driver's door is, you'll find it right there.
My thought is to just disconnect the ABS pump assembly, and basically fabricate jumpers to go around it. Needs more research, though. So far, I have just been tossing it around in my mind.
I'd cap the ABS ports, just to make sure I could go back to it if I ever wanted to. No sense having dirt and critters get in there and ruin it.
Not sure if this is helpful but the ABS control module of my '03 E250 failed, constantly sending voltage to the pump---I simply pulled the fuse which naturally triggered the dash light. Because that module would cost me $550 plus that particular van will be sold sometime soon I won't go to that expense. The ABS is disabled yet full braking is still available---if you don't mind the dash light you might do the same thing and avoid all the work of running new brake lines etc simply to bypass the ABS block up front.
violator4200
15
05-25-2020 05:59 AM
mgermany
06-30-2016 08:14 AM
peter.jones
05-08-2009 10:01 PM
