Doors stuck!
Old May 22, 2019 | 08:22 AM
05XCRSN's Avatar
05XCRSN
Doors stuck!
Has anyone else had issues with their doors getting stuck closed? Acts like it's locked. I can see the pull moving up and down. So the actuator is working. It won't open from the inside or the out. Child lock should only lock the inside handle, right?
Old May 23, 2019 | 12:42 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yes, child lock only locks the inside handle. Something inside is loose or worn out. The whole setup is really quite simple once you get the door panel off. Take the panel off, and watch all the moving parts while the problem is showing itself.
whimsymaker
Oct 11, 2017 12:05 PM
K trout
1997 - 2003 F150
May 12, 2014 02:29 PM
jo15765
Sep 6, 2013 10:15 PM
CT Cruiser
Jul 19, 2006 03:11 PM
cg208cm
Apr 3, 2004 08:11 AM
