Step stools / step ladders for current Super Duty
Old May 21, 2019 | 11:22 PM
Army RET's Avatar
Army RET
This afternoon (while hitching up my fifth) I finally decided it was time to purchase a dedicated step stool / step ladder; when my fifth wheel is attached there is simply no way I can climb into the bed of my (non-lifted) truck. It's a bi**h getting old(er) - but it beats the alternative.
I'm thinking of storing it in the bed; are there any recommendations on decent light-weight steps/ ladders that are cheap enough so that if it's been stolen it can be economically replaced - yet one not susceptible to the weather elements if left alone?
I'm thinking about a $50- $70 range;
Amazon Amazon
Old May 21, 2019 | 11:41 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Those are good. We have one at the office. It may not work so well in soft sand and gravel though.
Old May 22, 2019 | 05:13 AM
jsm180's Avatar
jsm180
Old May 22, 2019 | 06:04 AM
Edkajo's Avatar
Edkajo
I just take along a good 4' step ladder. Not a perfect solution but it lays across the back of the bed between the hitch and the tailgate or the hitch and the tool box just fine. Comes in handy for other things on the camper as well. Obviously the ground surface matters but that always does..
https://www.homedepot.com/p/Werner-4...E&gclsrc=aw.ds
Old May 22, 2019 | 09:41 AM
Edd505's Avatar
Edd505
I use one of these, lays in front of the tail gate with a bungee to the hooks in the bed corners.
https://www.homedepot.com/p/Werner-4...-202059651-_-N
Old May 22, 2019 | 12:47 PM
rameyer's Avatar
rameyer
I use one of these.
Wheel Step Wheel Step
Old May 22, 2019 | 01:12 PM
Army RET's Avatar
Army RET
This morning I was at my RV dealer (drop off for t'stat problem) and across the street was a Lowes.
They didn't have a large assortment on site but this one met my minimums and came home with me; under $50 out the door (with my military discount).
https://www.lowes.com/pd/Werner-4-ft...Ladder/1114149
Old May 23, 2019 | 03:26 PM
traveldawg's Avatar
traveldawg
This has been my favorite for years through multiple trucks:
Cosco 3 Step Lightweight Step Ladder Cosco 3 Step Lightweight Step Ladder
Old May 23, 2019 | 07:46 PM
Bdox's Avatar
Bdox
Perfect choice. very durable and hold up well in constant sunlight.
Old May 24, 2019 | 05:55 AM
Edkajo's Avatar
Edkajo
Whatever is chosen keep in mind the weight rating matters. The 225lb rating can be touch and go for most average size guys,( maybe not so average) especially outdoors when some surfaces may not be completely level. At 200lbs I generally find the 250lb rated ladders about the minimum I feel comfortable using, the 300lb rated ladders, even better.
Old May 24, 2019 | 08:43 AM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
I use this lightweight Rubbermaid plastic ladder.
Old May 27, 2019 | 09:38 AM
5851a's Avatar
5851a
Those fiberglass ones are nice, had my doubts till I used one. Around here you would need to lock it up. A friend did AC work and went up on roof of a quick mart, wasn't up there 5 minutes. Had to call for help because someone stole the Werner ladder.
Old May 27, 2019 | 12:44 PM
klbrown's Avatar
klbrown
I have this one from HD. Cheap, lightweight and enough steps to reach into the bed and a few other things around the 5th wheel, inside and out.
I have a tonneau cover so the ladder is out of sight when I'm not hitched up. When traveling I just toss it in ahead of the 5th wheel hitch and can
step on my extended running board to reach in a grab it when needed.
https://www.homedepot.com/p/Gorilla-...-205804012-_-N
Old May 27, 2019 | 08:51 PM
xrated's Avatar
xrated
Here is what I use for the same purpose....5ver hooked up or ready to unhook and I can't get in the truck bed....
https://www.amazon.com/gp/product/B00291AXUU/ref=ppx_yo_dt_b_asin_title_o03_s02?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00291AXUU/ref=ppx_yo_dt_b_asin_title_o03_s02?ie=UTF8&psc=1
When folded up, it goes in the baggage compartment of the fver.
Old May 28, 2019 | 12:47 AM
Bdox's Avatar
Bdox
Great stuff X!
