Brake Switch
Old May 21, 2019 | 04:11 AM
Navistar86's Avatar
Navistar86
Brake Switch
I have a 2019 f350 lariat with 6.7. This past weekend I struggled to get the shifter out of park. Cycled the ignition a few times, pumped the brake a few times and it finally shifted out of park and has worked perfect since that occurrence.
Anyone else had this happen? I would assume it's the brake pedal sensor that releases the shifter
Old May 21, 2019 | 06:01 AM
Txwhitetailhunter's Avatar
Txwhitetailhunter
Is it possible that your wheels were turned a bit? On a hill? The steering wheel lock could have been adding pressure to the shifter. A slight turn left or right would remove the pressure and allow you to shift from park.
Old May 21, 2019 | 09:31 AM
Navistar86's Avatar
Navistar86
Yea I was turning the steering wheel and pumping brakes but it took a few minutes to get out of park.
Old May 21, 2019 | 11:02 AM
novi408's Avatar
novi408
Keyless ignition? Could be the "police mode" I've read is factory enabled in 2019. The truck may not detect the key and prevents it from shifting out of park.
69ford99
1997 - 2003 F150
13
Jan 24, 2024 04:45 AM
Brackett127
Sep 26, 2012 08:39 PM
marragtop
Mar 5, 2009 05:26 PM
TeamG
Dec 26, 2006 04:26 PM
EZTrader
1978 - 1996 Big Bronco
Sep 9, 2003 05:03 PM
