Lower portion speedometer cable
Old May 19, 2019 | 09:35 PM
Odisvan's Avatar
Odisvan
Well, I guess after buying an installing a supposed to fit fleabay lower speedo cable, to replace my broken one, I’m going to have to try and order a factory one. Anyone had any luck with part number or vendor? I sure want my speedo back and it’s just hit or miss on fleabay and Amazon. 1984 f150 302 2v carb, auto. Thanks for your help.
Old May 19, 2019 | 10:53 PM
ctubutis's Avatar
ctubutis
I find D4AZ-17262-A in the books, I wonder if that's correct... @NumberDummy
If so, I also found this:
https://www.ebay.com/p/Ford-OEM-Spee...les/1911251610
Or do you want the whole cable + housing assembly?
Old May 20, 2019 | 04:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Chris, 17262 is just the woven steel core inside the speedo cable housing.
If the OP wants a lower speedo cable, the truck has factory installed Speed Control.
E0TZ-9A820-E .. Lower Speedometer Cable - Use with factory installed Speed Control - 50" long / Marked: E0TA-EA / Obsolete
1980/85 F100/350 2WD with A/T
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 460 = 800-476-9653.
Old May 20, 2019 | 07:24 AM
Odisvan's Avatar
Odisvan
Thanks guys. I guess I could actually just leave the cruise control part out of the equation as I cannot use it on ANY vehicle around here anymore. Haven't ever turned it on in anything in years. In fact, I disconnected the chain thing to the carb in case my son drove it and accidentally turned it on, in case it malfunctioned. As this truck sat for YEARS.....
I bought a pioneer or some brand off fleabay supposed to fit, but the inner core wire isn't same diameter as stock, and it turns inside the speed control electrical switch between upper and lower cable (and literally wraps my speed control and wires into a neat bundle). I didn't have to even get out of driveway to hear it wrapping around. So tired of half what I do I have to redo from incorrect info on ebay, amazon and parts store computers. Box stores will give you wrong stuff in a heartbeat too. Fortunately, it's not a hard or dirty job, fairly painless to redo.
Old May 22, 2019 | 09:12 AM
Odisvan's Avatar
Odisvan
ordered stock one from Dennis Carpenter, $24.95 plus 9.95 shipping. I was going to use free cellphone app speedometer, but decided that'd be unsafe for an old goober like me. Well worth $35 to not glance away when I shouldn't be. Plus, I don't like seeing new tech in old cars, I like things to look period correct if at all possible. Thanks again.
Wyowanderer
May 5, 2017 12:53 PM
mjricha.isu
Jul 9, 2015 07:41 AM
crazyredneckanyhow
WTB - Parts & other
Apr 12, 2012 12:17 PM
84-6.9L
Apr 20, 2011 10:21 PM
evin
Apr 28, 2004 05:52 PM
