1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
My odd oil burning problem.... Well odd to me.
Old 05-18-2019, 08:13 PM
Sean Smith's Avatar
Sean Smith
Sean Smith is offline
02 F-250 SD with 5.4 - Cylinder 2 has oil on the plug but compression check is 142 psi all other are 150- 160. The truck has zero trouble starting and sounds quite when running.
When I first start my truck it will make a huge cloud of Blue Smoke then it will Idle rough. Wait 10 min or so and the tail pipe will stop poring out blue smoke and be normal, no color tail pipe exhaust. Still having a rough Idle though. The truck will run fine if I keep the RPM under ~2500 but still be rough and have no power. Go full throttle and the truck will bog down and start vibrating like a kid playing with a toy machine gun but no smoke will shoot out the tail pipe. I had a car follow me to watch for it. If I take the truck up a hill and the rpm goes over ~2500 then a light blue smoke will appear until I get off the hill and the rpm drop then back to normal exhaust. Get home still rough Idle. Park it and start it ~5 min later no smoke. Park it and wait 30 mins or more and the entire block will fill with smoke. This cycle keeps happening.
What do you think is wrong?
Old 05-19-2019, 07:28 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
valve guides and seals..
Old 05-19-2019, 09:08 AM
redford's Avatar
redford
redford is offline
Received 1,574 Likes on 920 Posts
The full throttle bog sounds like a clogged catalytic converter.
Old 05-19-2019, 09:22 AM
leadmic's Avatar
leadmic
leadmic is offline
What both the above ^ posts said. The bad valve guides and seals caused the spark plugs to foul and cats to plug up. Do you have a check engine light How many miles?
Old 05-19-2019, 09:31 AM
Chuck's First Ford
any filter.. air, oil, fuel..
does its best filtering just before it becomes restrictive...
real TEST data is difficult to come by..
Old 05-19-2019, 07:23 PM
Sean Smith's Avatar
Sean Smith
No check engine light ever. I think my trucks ability to show that light is broken. The light does turn on when I put the key in run. Goes off when running. My obd scanner shows no codes and no pending codes. 142000 miles.
I know the problem now though. I have a bent valve somehow. Used a endoscope that can look at multiple angles using a mirror that clips on it. It is crazy though that my compression is so high with a bad valve!
The oil drip is slow but i seen it on the scope. It kinda fills the cylinder which is the crazy blue smoke after sitting. But don't smoke while running because it is not dripping fast enough to be seen at all times. The higher the rpm the more oil that shoots into the valve cover and instead of dripping into the oil hole it drips past the valve seal and into the cylinder.
jorge.s
02-02-2012 06:23 PM
71LTD390
17
09-09-2010 04:51 PM
Bergerson
17
04-16-2008 09:56 PM
2006f350fx4
08-12-2006 09:38 AM
86ranger-89mustang
1983 - 2012 Ranger & B-Series
05-11-2004 09:06 PM
Quick Reply: My odd oil burning problem.... Well odd to me.
