Continental Contitrac
Old May 18, 2019 | 05:34 PM
Semi Hex's Avatar
Semi Hex
So, I brought my 2018 F-350 used and it came with the above tires (275 65 18). I was told they would be great towing the fifth wheel and highway driving. The problem I’m having now is that at the 70 psi tire pressure in the rain, I have absolutely no traction on the lawn at the rv park, they slip at the painted lines on the road and forget trying to accelerate.
I cannot imagine that people are airing them down to 55 psi every time there is a bit of rain, or are they just not good in the rain. It has been raining pretty hard but these have been scaring the crap out of me.
I might be looking for something else.
Old May 18, 2019 | 07:59 PM
senix's Avatar
senix
Moved to the 2017 SD forum per request.
Old May 19, 2019 | 05:12 AM
Poncho450's Avatar
Poncho450
First thing I did after I bought my 2017 was sell the Contitracs and get some BFG KO2. Just about anything you select will be better than those particular Continentals.
Old May 19, 2019 | 05:31 AM
seville009's Avatar
seville009
I used to do the same thing.
Last truck that came with them I kept them as strictly summer tires. They are smooth as silk on dry roads, but pretty much useless for anything else.
Old May 19, 2019 | 05:36 AM
Poncho450's Avatar
Poncho450
I could tell that they'd be basically useless and winter was approaching. But the main reason for me to get new tires was because I wanted something that didn't look like a training wheel inside of the wheel well. The stock tires just looked so little in that big opening.
Old May 19, 2019 | 06:22 PM
dplado's Avatar
dplado
Worst tire ever
I had a set of these on an earlier Super Duty I owned. I did not feel safe with them in rain or snow. My dealer now will not sell a truck with them on and will upgrade them on delivery of vechile.
Old May 20, 2019 | 12:10 PM
Semi Hex's Avatar
Semi Hex
Thank you all for the replies. From reading other threads, I’ll be looking for some K02’s, Toyo or some other brand.
Old May 20, 2019 | 03:32 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
While I am in no way a fan of OEM tires....I have had zero problems out of mine...dry or wet. I do run 45-50psi in the rear though. I will replace them before winter comes
alanber
Oct 13, 2018 05:49 AM
Beavskis
Sep 26, 2017 12:52 PM
fishbones182
Sep 7, 2015 01:06 PM
pilot4x41
Apr 17, 2007 07:41 AM
DWToml815
Jul 11, 2006 08:05 PM
