Alternator wiring
Old May 16, 2019 | 01:20 PM
Dweber319's Avatar
Dweber319
Alternator wiring
In the diagram I've been referencing, it shows a connection from the stator on the alternator to the stator on the voltage regulator. But it also shows it tapped off to the ignition switch and the choke. Is this just to keep the choke energized so it has power when you crank?
The way it's currently wired is from the out of the starter solenoid to the ignition coil then to the choke.
If I leave the solenoid/coil/choke wiring the way it is should I still tap off from the stator to the ignition switch/choke or just run from the stator on the alternator to the stator terminal on the regulator?
Dweber319
Electrical Systems/Wiring
May 16, 2019 04:31 PM
Dweber319
May 14, 2019 09:47 AM
MTbuilder
Mar 7, 2010 10:42 PM
TheKirbyMan
Jan 14, 2010 01:37 AM
AU_Travis
Apr 30, 2003 04:26 AM
