In the last week been getting long crank to start when cold, I always wait for several seconds after injector buzz and glow light goes out. Would this be more likely the IPR screen or dummy plugs? After fully warmed up truck starts in 1-2 seconds, when cold it takes up to 4 seconds to start. I do have the Scangauge II and also the torque pro app. All readings seem ok but takes longer now to build pressure before starting.
My 2005 with 240,000+ miles has done this since the day I bought it.
Last year I had a new oil cooler, stand pipe, dummy plugs, egr cooler and valve, icp, all injectors, and starter (and I'm sure some things I forgot) replaced and my truck still takes 4-5 seconds to start in the morning,
Repairs were not related to the starting behavior.
Until last year the truck always ran great and it runs great after the repairs but nothing changed at all in regards to its starting behavior since new.
Not sure what this means but in my case it has always been this way and I accepted it as "normal".
Go into the settings and change the update speed to fast. The other option would be to get one of the ELM devices and
the software to run on a smart phone or tablet. Then if you want to do some data logging you have that option also.
Forscan adapter comes in a few flavors and even one that us USB so that you can use a laptop.
Here is a link to the site >>>FORScan
Thanks for the info, I have Forscan running on pc netbook now. Have entered in 28 pids so far.
What year truck?
If you have the wavy oil rails, or the late '04 and up, simply pull the ICP sensor after it's sat overnight or a few days.
If you don't have oil right there under the sensor you are leaking down in the oil rail.
This only works on the passenger side of course, without pulling the valve cover.
Oil was just changed in Feb this year, 1000 miles on it. Ran the ForScan injector contribution test, it made 2 passes no errors. No codes found. Like I said before, it starts right up when warm, 3-4 seconds when cold in am. Never have used any stiction products. Last oil was Rotella 15/40.
