Ways to improve the brakes on 05' Super Duty?
I've had my 05' Super Duty for a few years now. I really like the truck, but the brakes have always been sub par. They work, but they just don't compare to any of the newer trucks I've driven. I've flushed all the old fluid out with fresh DOT4 fluid, I've flushed the hydroboost system out with fresh synthetic ATF fluid, I've put new OEM rotors and Wagner HD pads on the front along with new front calipers, and new rubber lines. I haven't done much with the rears except new pads.
Even after all of this, the truck just doesn't stop as well as I'd like. Don't get me wrong, it will come to a pretty quick stop if I really stop on the pedal.......but you really have to stomp on it if you want to stop in a hurry....I can stop just as fast in other trucks I've driven with a pretty light foot.
Is this just how these trucks are? Are the brakes just not as good as the newer trucks? Is there any other ways to improve the brake feel on these trucks?
Thanks!
Thanks!
I've tried the "fancy" rotors before on other trucks. I put a set of those power stop slotted rotors on my last truck, and honestly....they didn't help at all. If you think about it, the slots are for "outgassing".....something you would see on a track or race car when you get the rotors glowing not. On a street car/truck...all the slots do is give you less contact area for the pads to grab. If slotted rotors were really a great idea, factory trucks would come with them....but they don't.
As far as using EBC yellow pads.....isn't that their race/track pad? Is that the best choice for a truck you are going to tow with? I bet they chew the hell out of your rotors don't they?
I put brand new calipers up front.....with brake new greased pins.
I'm on stock rotors and they work well.
They make a mess on my wheels but they stop me.
Ford F-250 Super Duty EBC Brake Pads | EBC Red Stuff Brake Pads | EBC Yellow Stuff Brake Pads | EBC GreenStuff Brake Pads
Shock absorbers play a significant role in the stopping ability of a vehicle, as do the tires. Now obviously this will not affect the brake pedal feel but it will play a role in the stopping distance of the truck. That is why it is important to pay attention to the stopping distances, both dry and wet, when reading tire comparison tests.
— Dave
— Dave
— Dave
— Dave
As stayed, stopping distance and not brake pedal feel.
— Dave
Yes, he would know if his shocks were completely shot, but if you go back and read my post I was speaking about stopping distance. A brand new shock will yield a shorter stopping distance (all things being equal) over the same model shock that is worn. Not destroyed bad worn but 75,000 miles worn. I have quite a few years of shock dyno experience and chassis setup experience.
— Dave
— Dave
Let's try the easy solutions first before he dumps 100's on shocks and it still isn't fixed.
— Dave
— Dave
Nah, on a super duty it might make a little difference but that's not what he described. I know exactly what he is talking about. My 01 was similar. I'm betting on heavy deposited/glazed over rotors. That's a night and day difference compared to 'worn' shocks and having to push hard before some action matches that symptom.
