Oil bath axle's
Old May 16, 2019 | 05:11 AM
kevin211's Avatar
kevin211
Oil bath axle's
Has anyone changed out axle's to from stock grease to oil bath. I have a 5th wheel trailer and was wondering if it's worth the money to go this route when the time comes.
Old May 16, 2019 | 11:10 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I know people that have tried them and went back to packing with grease because of constant leaking with the oil bath.
Denny
Old May 17, 2019 | 03:49 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I can't imagine it's worth the effort. They don't change the rating of the axle, just the repack interval.
They usually say the interval is to check the oil level on some regular basis and fill as necessary. That seems to fall hand-in-hand with the perception that they leak (as kevin211 noted above). Use them a while, some oil leaks out, check and refill, voila' oil never gets old!
You might see an advantage if you tow a lot of miles all the time, in the form of less downtime for repacks.
Old May 18, 2019 | 06:44 PM
2009kr's Avatar
2009kr
I've heard they are an issue if your trailer sits parked for the winter. Apparently the bearings outside of the oil don't get enough rust protection as compared to being covered in grease.
I was also told that while the hubs that came with my disc brake conversion kit had clear caps to support oil bath, you need much more expensive seals than the ones that came with the hubs.
After pondering this decision myself, I went with ole tried and true grease.
Old May 20, 2019 | 07:34 AM
wrvond's Avatar
wrvond
I have a 2002 boat trailer that uses oil bath hubs. It's never leaked and I've never had water intrusion. It's a very good system for that particular application. Since the hubs on my camper do not get completely submerged in water I don't really feel the need to have water tight hubs. If I need to work on the conventional hubs, they are much easier to take apart and put back together than an equivalent oil filled hub.
Originally Posted by 2009kr
I've heard they are an issue if your trailer sits parked for the winter. Apparently the bearings outside of the oil don't get enough rust protection as compared to being covered in grease.<snip>
I've not seen any rust issues with the bearing on my boat trailer. I would think that the system, being designed to keep water out, would be rust free unless there is a failure.
Old May 21, 2019 | 01:31 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I follow a hot shotter forum, and many of those guys converted from oil bath back to greased axles.
A/Ox4
66
Nov 3, 2013 09:04 PM
Wagion
All Things Towing
Aug 7, 2010 09:56 PM
DBGrif91
Aug 30, 2009 12:39 AM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Jul 30, 2008 05:20 PM
apropos
Garage & Workshop
15
Nov 1, 2005 11:06 PM
