6.0 air filter question
Old May 16, 2019 | 04:47 PM
TooManyToys.'s Avatar
TooManyToys.
SD has you covered. The only additions I do is after pulling the hose off the reservoir I put the end over one of the throttle body hose clamp studs. The MAF connector I fit behind the dipstick tube so it stays out of the way. The air filter minders tip gets a wipe of silicone brake grease so it’s easier to install/remove as do the locating tabs on the bottom of the filter that lock into the mounting grommets and the ID of the hose that mounts to the turbo boot. Sometimes to get the boot over the lip you can use a cotter pin removal tool or an Allen wrench like you're installing a tire on a rim.
leadfootal
Aug 5, 2008 02:53 PM
scottman70
Mar 17, 2007 11:54 PM
schlichtemeier
Feb 27, 2006 10:03 PM
Rich in CO
Jun 27, 2005 08:29 PM
RICE H8R
Dec 3, 2004 09:40 AM
