Trying to figure out if I have a R134a conversion or not, no labels. The low pressure port looks like a R134a port but the second picture is the one I am assuming is the high pressure port and is not quick connect.
The low pressure port is 134a. Like you already noticed, the high pressure port is not. Most homeowners doing a conversion fill the system and adjust the pressure by the low pressure port and do not even use the high pressure port.
PO said the AC was not work and unplugged the compressor and cut the belt. I'm curious if it was a r134 swap gone bad as the compressor spins freely. Could be it is just leaking too. Will find out soon enough.
Any suggestions on getting to the evap coil? Is it better to go from the engine bay or the cab? I'm sure it's full of junk.
Your only access is via the engine bay. Just undo the two clips and some screws securing the evaporator case halves. One bolt comes through the firewall, near the passenger's feet.
You don't need to break any lines to get the evaporator loose. It's been a while, but I think if you undo the fasteners holding the receiver/dryer, you can swing everything out as a unit.
On my truck, I only had a moderate amount of debris near the fan and resistor pack. The lion's share of crud had accumulated on the upstream face of the evaporator.
Given the fact that the rest of the truck has been packed with termites, stink bugs, bees, wasps and every other shape and form of bug mines probably full up... Those big cowl vents don't help. I considered putting screen in there.
My breather valve literally was completely sealed with bugs and oil.
If you get that coil cleaned out good, you won't believe how it improves the heat in the winter. Over the years as that coil sweats, all that dirt turns to mud and totally clogs up the coils so no air of any kind can get through.
