AC fitting Identification
Old May 15, 2019 | 06:17 PM
The_Scatch's Avatar
The_Scatch
Trying to figure out if I have a R134a conversion or not, no labels. The low pressure port looks like a R134a port but the second picture is the one I am assuming is the high pressure port and is not quick connect.
Old May 15, 2019 | 08:05 PM
Franklin2's Avatar
Franklin2
The low pressure port is 134a. Like you already noticed, the high pressure port is not. Most homeowners doing a conversion fill the system and adjust the pressure by the low pressure port and do not even use the high pressure port.
Old May 15, 2019 | 08:18 PM
The_Scatch's Avatar
The_Scatch
PO said the AC was not work and unplugged the compressor and cut the belt. I'm curious if it was a r134 swap gone bad as the compressor spins freely. Could be it is just leaking too. Will find out soon enough.
Any suggestions on getting to the evap coil? Is it better to go from the engine bay or the cab? I'm sure it's full of junk.
Old May 15, 2019 | 08:25 PM
kr98664's Avatar
kr98664
Your only access is via the engine bay. Just undo the two clips and some screws securing the evaporator case halves. One bolt comes through the firewall, near the passenger's feet.
You don't need to break any lines to get the evaporator loose. It's been a while, but I think if you undo the fasteners holding the receiver/dryer, you can swing everything out as a unit.
Old May 16, 2019 | 07:48 AM
Olds64's Avatar
Olds64
Old May 16, 2019 | 08:25 AM
The_Scatch's Avatar
The_Scatch
Originally Posted by Olds64
There's really no need to take the evaporator out of the dash. Use a flush kit.
https://www.amazon.com/FJC-2710-Syst...s%2C146&sr=8-3
I'm just trying to clean the air box and coils right now. But I will definitely flush it with something like that when the time comes.
Old May 16, 2019 | 08:43 AM
kr98664's Avatar
kr98664
While you're at it, remove the blower fan and the resistor pack, too. Expect to find a lot of pine needles, leaves, small rodents, etc. in there:
https://www.ford-trucks.com/forums/1...n-the-cab.html
On my truck, I only had a moderate amount of debris near the fan and resistor pack. The lion's share of crud had accumulated on the upstream face of the evaporator.
Old May 16, 2019 | 09:39 AM
The_Scatch's Avatar
The_Scatch
Given the fact that the rest of the truck has been packed with termites, stink bugs, bees, wasps and every other shape and form of bug mines probably full up... Those big cowl vents don't help. I considered putting screen in there.
My breather valve literally was completely sealed with bugs and oil.
Old May 16, 2019 | 05:08 PM
Franklin2's Avatar
Franklin2
If you get that coil cleaned out good, you won't believe how it improves the heat in the winter. Over the years as that coil sweats, all that dirt turns to mud and totally clogs up the coils so no air of any kind can get through.
warrant_ero
Jul 19, 2014 05:37 PM
tshrager
May 2, 2012 07:48 PM
norm9759
Sep 22, 2010 01:40 PM
Viksnut
Sep 10, 2005 11:42 AM
Luzer27
Jun 1, 2005 11:04 AM
