E350 Scratching Noise While Accelerating
Old May 15, 2019 | 02:35 PM
redux01867's Avatar
redux01867
I have a 2017 E350 (6.8L) chassis RV . When accelerating around 40 to 42 mph and 60 to 63 mph I hear a scratching sound (sounds like static or sandpaper on wood or metal). Doesn’t happen all the time, but more often than not. Doesn't happen when cruising. Seems not to affect performance, Ford service couldn't find anything wrong. This is a 2-wheel drive, not a 4-wheel drive. Any help solving this mystery greatly appreciated.
Old May 15, 2019 | 05:43 PM
NotJustaTruck's Avatar
NotJustaTruck
Open the window and let the 🐈 in- probably hangin' on for dear life. LOL
All joking aside, I'd start by figuring out if the noise is occurring at a consistent RPM and then try to duplicate sound while revving engine in park. Perhaps there is a loose part somewhere that causes the sound. If it doesn't happen in park then you can focus on components that are in play while in motion. Could be something in brake rotors like a pebble stuck in pads causing it to rub in oscillation . I actually had this happen before. Sounded like light scraping noise and eventually turned to light squeal only at certain speeds. Good luck!
Old May 16, 2019 | 10:14 AM
redux01867's Avatar
redux01867
I'll give it a try. Thanks
Old May 25, 2019 | 05:46 PM
redux01867's Avatar
redux01867
The noise consistently started at 2000 rpm. Brought it in for service again. It was a deformed serpentine belt. Replaced it and noise gone. Simple as that. Thanks
jayman2
6.7L Power Stroke Diesel
24
Mar 17, 2012 07:00 PM
4Ranger4
1983 - 2012 Ranger & B-Series
31
Sep 26, 2010 07:31 AM
74baja
Jun 27, 2010 08:27 AM
d0n_3d
1997 - 2003 F150
Jun 3, 2004 06:05 AM
modog
Apr 3, 2004 11:44 PM
