You don't need a pinion depth tool, just set it up first with the factory shim thickness and run a pattern to see how it's cutting, then adjust as necessary.
I haven't used a case spreader a large dead blow hammer has always worked for me. What size tires are you running? Personally I wouldn't switch to 4.10s unless I had 37s or larger.
I had a '96 with 4.10's and I liked how it pulled a much smaller horse trailer (with much less hp) than I have now. My minimum GCVW is 17k..on 275/70-18...like 34".
It's a tow pig. I'm super fine with a few more rpm over the 265/75-16.
34-35s with 4.10s and the SXE would be sweet! Let me know when you get your gears down and Ill drop the truck off so you can do it again
