Timing....
Old Jul 13, 2009 | 01:43 PM
SeattleWills's Avatar
SeattleWills
Timing....
Ok first off this is my first go at setting my own timing. I have recently rebuilt my Carb 1405 600cfm Edelbrock, I have also installed MSD, Distrabutor, Coil, Wires, and 6A ignition control. I have set my timing to 8 BTDC, Truck is running good but not perfect. At low rpms it is sluggish and lags if I put it to the floor, on the highway it runs awesome. I am looking for any direction to go... should I bring it back to zero 1 degree at a time and test drive the truck each time? I am lost as to do next. Thanks!
Old Jul 13, 2009 | 01:54 PM
montana_highboy's Avatar
montana_highboy
Is your vacuum advance connected? is it working?
Old Jul 13, 2009 | 04:09 PM
SeattleWills
Yes, I have checked that, I did put a new vacuum line from it to the carb. The new MSD Distrabutor has the light springs in it, I do have some medium and heavy ones. Do thing changing them to a stronger set would help? Is my time pretty good at 8 btdc? I was going to bring it down to 6 btdc.... again I am new to this and only have the information from books and other people. I am learning as I make changes and find out they didnt work. I just dont want to damage my engine it is strong and I love it! Again thanks again for any help.
Old Jul 13, 2009 | 04:28 PM
montana_highboy
Did you connect the vacuum advance to the ported or manifold side of the carb? ported (passenger side) manifold (drivers side)
If you're running 2 light springs you may be bringing in all your timing too quickly, this will take some expirmentation on your part using the light, medium and heavy springs, is your vacuum canister the adjustable type?
8 btdc is pretty close to where you want to be, i run 12 degrees initial on my 390 but i'm only running 26 degrees mechanical, total 38 all in by 2,600 rpms, how much mechanical advance are you running?
Old Jul 13, 2009 | 07:27 PM
duste's Avatar
duste
Is your 8 degrees timming set with the vacuum hose on?? If so remove and cap the vacumm hose, reset the timming to 8/10 degrees and put the hose back on. This will make a big difference.
Old Jul 13, 2009 | 07:43 PM
427 fordman's Avatar
427 fordman
I can't remember which springs are which for the msd but I run that dist. in all 3 race cars. My sisters car I have set up so the timing is at full advance (36*) at 1000 rpms. It's a stock 351w with a 4 barrel and headers, 8:1 stock dished pistons with 100000 miles on them and a 3300 lb car. Pulls the front wheel off the starting line with a c4 tranny and small convertor. Better have a good starter if doing this because of all the advance at start.
Old Jul 13, 2009 | 08:15 PM
SeattleWills
I did the timing with the vacuum plugged. It is also plugged into the passenger side of the Carb. I will try stiffer springs also. Thanks for the replies guys. Sounds like I will have to do some experimenting to get it the sweet spot. I dont have a tach yet, that will help. I can plug it directly into the ignition controller.
Thanks
