NP273 Chain Slack
Old May 11, 2019 | 07:31 PM
EXSwap's Avatar
EXSwap
NP273 Chain Slack
Posted this in the transmission forum with no luck. Anyone know the spec on the amount of allowed chain slack in a transfer case? I’ve got a bit of deflection. I’d like to take care of it now if necessary. Thanks!
Old May 11, 2019 | 09:42 PM
Flyboy1100's Avatar
Flyboy1100
that doesn't seem too bad, but i can't find any documentation or spec either.
Old May 12, 2019 | 08:29 AM
EXSwap's Avatar
EXSwap
It’s very odd that I can’t find a manual for these....
Thanks for the response! I’ll think on some more, but a 75 chain seems like good insurance.
Old May 12, 2019 | 09:36 AM
Flyboy1100's Avatar
Flyboy1100
You already have it apart, so I agree and would do the same. Post a pic of the new one installed
Old May 12, 2019 | 11:16 AM
EXSwap's Avatar
EXSwap
Will do! I’m gonna try to do a “how to” specific to changing the input shaft, but other stuff will be covered as well.
Old May 12, 2019 | 07:01 PM
thor363's Avatar
thor363
Git 'r done! I'm living vicariously through you until I can get back to my conversion project here also!
Old May 12, 2019 | 08:13 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
The factory manuals have complete tear down and rebuild info. Have you looked there for the chain tension specs? My manuals are up at the farm, or I would look for you.
Old May 12, 2019 | 09:22 PM
thor363's Avatar
thor363
Not much you'll find there guys.
From my 2003 MY Excursion Ford factory manual set, section 308-07B contains no notice of tension, Step 34 only mentions 'Install the drive sprocket, the driven sprocket, and the drive chain as an assembly.'
Old May 12, 2019 | 09:57 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
So, it is either "you like what you have" or "buy a new one"....no tensioner device.
Old May 12, 2019 | 10:11 PM
EXSwap's Avatar
EXSwap
Definitely no tensioner. And from what I’ve read, the chain getting loose and getting into the case is the major cause of grenaded transfer cases. I’ve looked several times for a rebuild manual as they normally have a spec like this, to no avail. I don’t have the ford shop manuals, but sounds like they wouldn’t be much help....I wonder if Allstate gear would tell me.
Old May 12, 2019 | 10:12 PM
Flyboy1100's Avatar
Flyboy1100
i looked in mine, didn't see anything
Old May 13, 2019 | 09:35 AM
EXSwap's Avatar
EXSwap
Thanks for the additional info guys!
I also wonder if maybe @Mark Kovalsky or @pirate4x4_camo would know of a source for the spec. Gents, any insight?
In any case, new chain ordered today. Hopefully I'll have it by end of week and I can get this thing out of my garage and to the X for mockup and eventual install. Still lots of work to do!!
Old May 13, 2019 | 09:48 AM
pirate4x4_camo's Avatar
pirate4x4_camo
factory manual would have been my suggestion and that didnt pan out.
the only thing i have ever done to a chain drive Tcase is blow them up and replace it with a junkyard unit. chain drives are like Bic lighters to me
all my T-case rebuilding or modifying experience is with gear driven units.
Old May 13, 2019 | 10:15 AM
EXSwap's Avatar
EXSwap
Part of me knew that would be the case...
Thanks!
Old May 13, 2019 | 10:48 AM
pirate4x4_camo
you already have a new chain enroute so install it but that one doesnt look bad to my eye.
if I was rebuilding one and really wanted to know the spec rather then use my eyecrometer and guess i would call these guys.
https://torqueking.com/product/50255...-ford-gmc-ram/
