Bench Seat Identification
Old May 10, 2019 | 01:00 PM
SixtyFour's Avatar
SixtyFour
Can anyone identify the year my bench seat is? Thinking 70's?
Old May 10, 2019 | 02:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It might be the original bench seat, but it has been reupholstered and doesn't match what the original upholstery looked like, which was vinyl.
There may be a metal strip (buck tag) with an ID engineering number stamped on it attached to the seat frame or wired to the seat springs.
The prefix of the number will be for whatever year your truck is. 1965 example could be: C5TA, C5TB or C5T something.
This tag was installed by the maker of the seat frame who also installed the upholstery. It was not installed by FoMoCo, the seats were purchased from outside suppliers.
Assembly line workers decoded the ID number, which would enable them to install the correct seat that matched the build sheet.
Old May 10, 2019 | 02:59 PM
SixtyFour's Avatar
SixtyFour
It might be the original seat, but it has been reupholstered and doesn't match what the original upholstery looked like, which was vinyl.
There mat be a metal strip with an ID engineering number stamped on it. The prefix of the number will be for whatever year your truck is.
Ok i'll look for a tag, thanks. Also another reason i don't think it's original is the latch to fold the seat back forward contacts the gas tank if the seat is in the rearmost track position. Unless this is just a poor engineer design of the stock seat...
Anyways looking to redo my interior and want to get a new cover for whatever ERA bench I have.
Old May 10, 2019 | 03:08 PM
NumberDummy
This may help...
Old May 10, 2019 | 03:15 PM
SixtyFour's Avatar
SixtyFour
Thanks ND. Do you have diagrams of the 70's era to compare to?
Old May 10, 2019 | 03:28 PM
NumberDummy
Upper pics & Lower (lower) pic:
Old May 10, 2019 | 03:36 PM
SixtyFour's Avatar
SixtyFour
Based on that diagram and part# 62648 i think it's definitely a 73/77 bench. You can see that same latch in my second pic.
did the original benches fold forward?
Old May 11, 2019 | 09:10 AM
john jamieson's Avatar
john jamieson
Original seats do fold forward but do not have the latch. At least mine don't.
john
Old May 11, 2019 | 10:16 AM
James_Western_Canada's Avatar
My guess is, that seat is out of a 70's or newer truck, and that the truck it came out of was either a Supercab or Crewcab, as the only time I've ever seen FORD spend a nickel to finish the backside of the front seat is when there are more seats behind the bench.
Going one step further, the "tweed" with velour was more of an 80's thing........
Old May 13, 2019 | 01:45 PM
SixtyFour's Avatar
SixtyFour
This is helpful thanks. Number Dummy if you see this do you have 80's seat diagrams?
jdscooby
13
Jul 21, 2021 10:35 AM
The Hill Boys
26
Jan 10, 2016 09:49 PM
johnson.jeff.a
Dec 4, 2015 09:17 AM
rtcalabrojr
28
Jan 14, 2012 10:54 PM
