Who's running a CB?
Old May 11, 2019 | 11:00 AM
Mudsport96's Avatar
Mudsport96
This thread is making me want to stick one in my truck now... And I'm wishing I hadn't sold all of my old goodies.
Old May 11, 2019 | 11:14 AM
sandymane's Avatar
sandymane
Most of our old junk is probably priceless now. . At least to us anyway.
Old May 11, 2019 | 03:18 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
I have a Firestick antenna mounted in a stakehole. Radio is the Cobra 75WXST. I like the Cobra a lot as I can disconnect it and store it when I do not run it, which is pretty much only when I am on the road. No real reason in the city, I have a portable HAM if I need to pick up weather band for city use.
Bought it all here - https://www.rightchannelradios.com/ Tons of info for setting up the SWR.
Hope it helps!
Old May 12, 2019 | 12:32 AM
Azryael's Avatar
Azryael
I had mine mounted up at the top in the double skinned section of the roof like Brian did, as I have a ZF5.
My equipment was junk and I could never get out to a place where I could properly tune it, so I've pulled it for now.
Old May 12, 2019 | 01:46 AM
Skip1970's Avatar
Skip1970
Originally Posted by Jarrett Campbell
I have my 102" steel whip mounted to the passenger frame rail between the cab and bed. The antenna whacks the cab every once in a while but no real paint damage yet.
My radio came with the 76 high boy I bought 4 years ago, works good but no clue what the range is on it.
hey buddy just get a tennis or hand ball poke a hole thru it and run it down your antenna so its between the bed and cab, thats what we used to do, then no more once in a while wacks.
Old May 12, 2019 | 03:31 PM
95fiveoh's Avatar
95fiveoh
All very nice installs. I ordered two Firestik II 3' black antennas, two Firestik medium springs, and two stake pocket mounts. I still have to get the coax, but that should be no big deal.
My truck is a manual so I have to be careful of exactly where I put the radio so that it doesn't interfere with the shifter, but I like the look of it mounted in/under the ashtray. And I'll mount a hanger for the microphone to the right of the gauge cluster where the push button 4wd buttons would be.
Old May 12, 2019 | 07:41 PM
Edgethis's Avatar
Edgethis
My truck had a CB in it when I got it. Haven't used it yet myself.
Old May 13, 2019 | 08:49 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Good idea! reps sent....
Old May 13, 2019 | 01:12 PM
Davidw45's Avatar
Davidw45
That's right where I have my mic mounted, works great. If you want more detailed pics of my ashtray mount just let me know. I pulled the ashtray and bracket out of the truck, then used 4 self-tapping screws to mount the CB bracket to the ashtray bracket, and then reinstalled it in the truck. Fits perfect and I have plenty of clearance for the shifter.
Old May 13, 2019 | 06:07 PM
95fiveoh's Avatar
95fiveoh
The more pictures the better!
Old May 14, 2019 | 06:53 PM
95fiveoh's Avatar
95fiveoh
Got the radio installed today. I'm very happy with where it is. I still have to neaten up the wiring and install the antennas and coax. Big question- where did you guys run your coax into the cab?
Old May 14, 2019 | 07:12 PM
Briansshop's Avatar
Briansshop
Looks good. Truck is clean!
Old May 14, 2019 | 07:56 PM
  #28
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
cb
Ran the coax under the carpet on the driver's side to the door. Then to the back of the cab and through a plug in the floor to the antenna mounted on my toolbox
Old May 14, 2019 | 08:29 PM
  #29
95fiveoh's Avatar
95fiveoh
Thanks Brian! I'll have to try to find that plug in the floor. I want to keep as much of the coax inside the truck as possible.
Old May 16, 2019 | 07:02 PM
  #30
95fiveoh's Avatar
95fiveoh
I got the antennas on and the coax run and hooked up. Running the coax neatly was a chore, I took out the seats and ran it under the carpet, and up.the middle of the bed, then ran the two cables separately out to the stake pockets. I'm glad I went with three foot antennas instead of four footers. I think they look great-
