Sponsored by: Real Truck
Gas mileage?
Old May 10, 2019 | 11:58 AM
geekwithoutacause's Avatar
geekwithoutacause
Originally Posted by rfcpatrick09
I see. I took some freeway to get home today and it improved to 7.6 but still not up to par. Surprisingly, vs range and mpg on the meter. gas gauge only has dropped a quarter since tuesday so maybe it's really a lie o meter.
I will do front, rear diff and transfer case fluid drain & fill. tranny drain & fill and fuel filter this weekend see how that helps. I was also going to do intake cleaning to see if that helps if it cleans carbon out
There is no fuel filter.
Do the math manually and do not rely on the dash meter.
What kind of terrain is those 5 miles ? 5 miles isn't much but it shouldn't be that bad. I'd expect to see 10mpg at least.
Old May 26, 2019 | 06:33 AM
CrimsonRide's Avatar
CrimsonRide
By the way I have f250 6.2 3.73 4x4 short bed cc
You sound like you have the same truck as I if tires are still stock. I’ve found that my truck takes several miles to warm up and settle in so to speak. The transmission takes the longest I’ve noticed. My commute is 19 miles one way so your tranny may not be reaching optimal temp - just a guess. It’s usually easy for me to stay in the 14’s empty. Try a longer trip this we or when you can and see what happens. Also, go ahead and give that ‘go’ pedal a little nudge- accelerating where she shifts between 2000-2500rpm sounds soo good and it’s probably not going to impact those mpgs too much lol.
Old May 22, 2023 | 09:43 AM
Pletch01's Avatar
Pletch01
4th Gear
Hi,
What's everyone getting? I just bought the truck and I admit I have been only using it for daily driving so far, about 5 miles each way, maybe a mile of it is freeway and relatively free of traffic. My monitor on the dash shows 7.1 mpg. Full tank range is only about 280 miles on 35 gallon tank and as I drive about half a mile, it always drops a mile in the range. I tried to rev less than 2k rpm and really light on the pedal. I almost wonder if anything is wrong with the truck. I see people are getting almost 11-12 mpg empty and that's like dream mpg for me at this point.
I do have about 300 lbs of sand in the bed but that's about all the load there is.
Any input appreciated. I am willing to try anything to get to that 11-12mpg empty in the city.
Thank you
just wanna say that you shouldn’t really be driving this truck that short distance constantly. It’s murdering your wallet but it’s also murdering your engine. Diesels are meant to have legs and you’re shooting yours in both kneecaps.
Old May 22, 2023 | 11:34 PM
abgiles1970's Avatar
abgiles1970
2nd Gear
Originally Posted by kcducttaper
I wouldn't trust the dash readout. Many times it's a rough estimate at best, but there is a chance it's just wack and you're not actually burning that much gas. Do the math yourself at the gas station to see what you're actually getting.
What you state is true, and this completely baffles me. I've had every kind of American Made truck out there, and have never had any of them within 15% accuracy, yet both the 2007 Tundra and 2012 Tacoma that I owned were absolutely dead nuts on in accuracy, comparing them to calculated. If Toyota has done it for so long, why can't our manufacturers here do it?
Old May 23, 2023 | 06:25 AM
Split rims's Avatar
Split rims
Four year old thread.
Old May 23, 2023 | 07:47 AM
Akley88's Avatar
Akley88
and the OP said he had a 6.2 gas not a diesel
hendu4672
May 22, 2023 06:01 AM
Rtr2017!
Sep 4, 2018 05:18 PM
PFG
6.2L V8
52
Jun 16, 2016 01:38 AM
tseekins
2009 - 2014 F150
Oct 19, 2013 11:56 AM
jg96powerstroker
20
May 25, 2011 07:33 AM
