dies then no start while hot
Old May 8, 2019 | 06:05 PM
puller45's Avatar
puller45
2003 7.3 dies intermittently without warning, will restart after cool down for about an hour. changed cps, fuel pump is running fine, new fuel filter, oil, and oil filter. dies like the key is shut off and runs fine when it will finally restart. I'm suspecting IPR, but would like feedback please. I disconnected the Edge tuner without any affect. I don't have a code reader, so I'm a little blind.
Old May 8, 2019 | 06:35 PM
z31freakify's Avatar
z31freakify
Might be IPR O rings or the solenoid itself goung bad.
Old May 8, 2019 | 10:04 PM
Wes444's Avatar
Wes444
Sounds like you would be able to easily test the suspect IPR. Carry a can of compressed air for computers with you on your next drive, when it shuts off invert the can, and blast the IPR solenoid for a few seconds, then try and restart. If it starts after chilling it all signs point to bad IPR.
Old May 8, 2019 | 10:17 PM
puller45's Avatar
puller45
I had thought of trying to cool it, but had not considered canned air. Good plan, thanks.
Old May 9, 2019 | 09:50 AM
HKusp's Avatar
HKusp
Canned air or small bag of ice. Check the tinnerman nut and make sure it is tight on it too while you are at it.
Old May 9, 2019 | 11:40 AM
F250_'s Avatar
F250_
This is WIERD. I posted the first reply to this thread a while ago, but now it is nowhere to be seen!
I agree with the IPR assessment.
Old May 9, 2019 | 11:46 AM
F250_'s Avatar
F250_
I see what happened... there are actually TWO threads with the identical Title and identical first post. I first responded in the other one, and the rest of you responded to this one!
Old May 15, 2019 | 04:00 PM
puller45's Avatar
puller45
Sorry about that couldn't figure out how to delete second post. Problem still with me' sitting by the side of the road waiting for it to cool. I tried the canned air cooling, still no start. Beginning to suspect the hpop.
Old May 15, 2019 | 04:47 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
On a hot shut down like that, you are usually looking at a bad o-ring or IPR valve. When the oil gets hotter and thinner, it finds it's way out of the high pressure loop through the weak spot. It is usually the IPR o-rings, but could also be a bad o-ring on an injector. The "leak" causes you to lose enough pressure in the high pressure oil supply to cause the truck to shut down. Once the oil cools, it is too thick to squeeze through the weak spot, and the truck will run until it heats up again.
This does not rule out a fuel issue, it is just the most likely scenario based on our collective years of experience here.
Old May 15, 2019 | 06:51 PM
Gaugepro's Avatar
Gaugepro
When it does not start next time get a pitcher of cold water and pour it over the HPOP. If it starts after then you have a HPOP issue or IPR. If not its under the valve covers.
puller45
May 9, 2019 10:55 AM
Idaho Hillbilly
Jan 30, 2016 04:03 PM
pete98cobra
Aug 27, 2011 03:08 PM
mzeigler27
Oct 31, 2008 01:18 PM
toadx8u
Mar 27, 2007 09:57 AM
