In trying to determine what is wrong with the horn on my '61 F100, I've figured out that - other than not looking good - the large gap between the steering wheel and the shifter is part of the problem as the spring contact on the column isn't touching the steering wheel (see pics below). My question is, to close the gap, do I simply loosen the bolts holding the column to the dash and move the column up, or will that cause problems with the shifter not engaging gears? The steering wheel is as far onto the splines as it can go, so the issue isn't there.
For bonus points: were the shifter housing and shifter originally black like the column? I'd have thought ivory like the wheel, but there's no evidence of that on my truck.
On my trucks and all that I've seen,(not all that many lol), the column matches the wheel. I would guess that your column has been replaced.
One thing that will affect the gap is the condition of your cab supports. If the rubber is squashed and the supports are rusted and collapsing than you can get that effect. If those are good, I would try loosening the dash attachment bolts and the the clamps on the engine side and see if you can move the column.
john
Early 60's columns have a flange on the bottom of the column that bolts to the firewall and is not adjustable up or down. The shaft goes into the steering box (one complete unit). Prognosis; cab is collapsing into the frame (rust repair needed). Parts are available but skill is needed. What do the areas were talking about look like?
On a 1961 Custom Cab the steering wheel would be white and everything else on the column would be black. If it was a Standard Cab then the steering wheel was also black.
In some trucks there is some adjustability to pull the column up to the wheel. Loosen the strap that holds the column to the bracket bolted to the bottom of the dash. See if you can pull up on the column to the wheel and tighten the straps. The spring under the wheel tends to push the column down. This may take 2 people. 1 to hold the column up and the other to tighten the 2 bolts on the strap. I had the same issue on my 64 when I put it back together. Worked for me
