Changing Tire Size
Old May 6, 2019 | 11:19 PM
62KR's Avatar
62KR
Changing Tire Size
So now that I went from the factory 18's with 275/17/18 tires to the factory 20's with 275/65/20, I would like to use Forscan to change my tire size so my speedo is correct.
I am seeing a lot of conflicting info on this. I have used forscan almost two years ago to make some changes.
Does anyone have step by step instructions for this that does not produce a check engine light?
Thanks
Old May 7, 2019 | 05:41 AM
Joe T's Avatar
Joe T
You may not need to. I went from the factory 20s to 295s exactly 1 inch taller and my speedo is still accurate. Using Waze on my phone which is GPS speed.
I dont think the 275/70/18 and factory 20 are even an inch apart.
Old May 7, 2019 | 08:27 AM
MBaldo's Avatar
MBaldo
With 35" x 20" Wheels, my speed is exactly 5 MPH off. I'd like to adjust mine as well.
Old May 7, 2019 | 09:55 PM
pickncrew's Avatar
pickncrew
following...
Old May 7, 2019 | 10:22 PM
bowler304's Avatar
bowler304
I read this on the internet a long time ago, but it was an article saying Ford use to set up the speedo for the largest tire for that truck. So when I went to 33" tires in my F150 my speedo was actually correct as it was the tire on the Raptor at the time.
Don't know if that is true but made sense at the time.
68cabby
2009 - 2014 F150
67
Dec 29, 2014 09:01 AM
69F250CrewCab4x4
Jan 17, 2010 09:38 PM
chado
2004 - 2008 F150
Jan 14, 2010 07:19 PM
TXHillCountry
Mar 15, 2007 02:51 PM
1MARK
Jul 30, 1999 10:50 PM
