Cruise control not workin
Old May 5, 2019 | 09:34 PM
Dunsparth's Avatar
Dunsparth
my cruise control wont work in my 94 7.3 IDI, i don't know much about these systems but what i have done is replace all the fuses under the steering column so far and still is not working where else should i start to check? it's not the end of the world if i dont have it but would be nice.
Old May 6, 2019 | 06:24 PM
genscripter's Avatar
genscripter
My '88 cruise control requires vacuum pressure. I don't know if the '94 has the same setup, but if it does, try looking for any kinks or breaks in the vac hoses leading up to the cruise control unit.
Old May 7, 2019 | 12:27 AM
DarkOverCast's Avatar
DarkOverCast
Iirc in mid 92 when they went to the serp belt setup they also went to electric cruise, they rarely give trouble. I would replace the brake switch first. Double check your fuses with a test light on each side, maybe the cruise isn't getting any key on power?
ford9303
Apr 30, 2014 10:21 AM
GuitarJesus
Jun 26, 2012 08:54 AM
silverxlt
2004 - 2008 F150
Mar 3, 2006 08:36 PM
jeepin
Electrical Systems/Wiring
Aug 17, 2003 08:13 PM
BB2
Aerostar
Jun 12, 2001 06:35 PM
