Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Dump truck
Old May 5, 2019 | 08:22 PM
Mikeyjoe84's Avatar
Mikeyjoe84
Dump truck
I'm having a hard time with figuring out what year this is even motor and trans any help would be appreciated
Old May 5, 2019 | 09:33 PM
jmtbiggin's Avatar
jmtbiggin
Number dummy while bee around shortly.
Old May 5, 2019 | 09:43 PM
Mikeyjoe84's Avatar
Mikeyjoe84
Thanks,you so much
Old May 5, 2019 | 11:21 PM
85e150's Avatar
85e150
Based on the HP rating might be a 534.
Old May 5, 2019 | 11:28 PM
Mikeyjoe84's Avatar
Mikeyjoe84
Thanks I will look into it some more.
Old May 5, 2019 | 11:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It's a 1967 T850 w/a 534 4V (T is an F series with tandem axles), main trans is a (Edit) Dana/Spicer 5 speed, auxiliary trans is a Fuller 3 speed.
It was assembled in KY, ordered from Seattle.
I'll decode all of the Warranty Plate codes tomorrow, Silent Sunday Night just began on TCM
Old May 5, 2019 | 11:56 PM
Mikeyjoe84's Avatar
Mikeyjoe84
It's a 1967 T850 w/a 534 4V (T is an F series with tandem axles).
Thank you very much, looking forward to it
Old May 6, 2019 | 02:01 PM
NumberDummy
T85 = T850 (gas). T is an F series with tandem axles.
L = 534 4V
U = Louisville KY Assembly Plant.
A45683 = 1967.
176" Wheelbase.
M = Wimbledon White.
T855 = T850, 45000 lbs. GVWR
681: 6 = Black all Vinyl / 81 = 81A Standard Cab.
BN: B = Fuller model 4C75 3 Speed Manual Auxiliary Transmission // N = Dana/Spicer model 6352 5 Speed Direct.
9FG:
9F = Eaton model 34DS Forward Rear Single Speed Axle / 7.17-1 / 34,000 lbs. Capacity & Eaton model 34RS Rear Rear Axle.
G = Rockwell/Timken model FF-903 12,000 lbs. Capacity Front Axle without Center Point Steering.
45,000 lbs. Gross Vehicle Weight Rating.
235 net HP @ 3,000 RPM
740703:
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
0703 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
1967/69 F/T800/1000 use the same cab & doors as: 1961/64 F100/1100; 1965 F100/250 4WD; 1965/66 F350/1100; 1966 F250 4WD
All the weatherstrips are reproduced, but the repro parts sellers don't list them for 500 and larger series trucks, so you have to order them for F100/350.
All the internal parts of the doors are also the same, some are repro'd, some are not, but may be available NOS
Old May 6, 2019 | 09:21 PM
Mikeyjoe84's Avatar
Mikeyjoe84
L = 534 4V
A45683 = 1967.
176" Wheelbase.
9FG:
740703:
Thank you so much for all the information,I just got it running today,next brakes and clutch,it's been sitting a while but the motor purrs, thanks again for all the info!!!!!
Old May 7, 2019 | 08:33 AM
Hillbillysuv's Avatar
Hillbillysuv
Gotta love the old Super duty engines. I'm surprised by how easily mine starts up even after sitting for a few weeks.
Old May 8, 2019 | 06:34 AM
finn's Avatar
finn
L = 534 4V
A45683 = 1967.
176" Wheelbase.
9FG:
740703:
Number dummy, are you sure the cab is the same on the T series. The pictures show that this particular truck has the raised roof, as do all of the Super Duty cabs towards the end of the run for that type cab.
the lighter trucks, including pickups and mediums retained a flatter roof.
Old May 8, 2019 | 06:58 AM
NumberDummy
Yes, it has the raised roof, but the windshield and back glass are the same, the doors and their internal parts are the same, as are all the weatherstrips.
So, if the OP needs any of these parts, he won't have to look for T800/1000 only parts.
mctooo
62
Apr 24, 2021 07:34 PM
eberf
Mar 4, 2017 10:31 AM
sandiballs287
Sep 23, 2009 09:18 AM
packoo
General Automotive Discussion
19
Nov 7, 2007 09:35 PM
jetjock16
Jun 7, 2003 12:42 AM
