Crank no start
Old May 4, 2019 | 05:13 PM
Shakes88lb's Avatar
Shakes88lb
Crank no start
Hey guys, need a little help. Have this 97 expedition that sat for 5 yrs. Ran good before that. Have a crank no start, no spark at plugs, no power to coil packs. And cannot connect to computer. Don't believe it's the anti theft, no flashing light. Any help and suggestions would be greatly appreciated thanks
Old May 4, 2019 | 06:09 PM
projectSHO89's Avatar
projectSHO89
Check the fuses for the PCM as well as the PCM Power relay.
Old May 4, 2019 | 06:17 PM
Shakes88lb's Avatar
Shakes88lb
All fuses are good. Is relay under hood or inside fuse block do you know
Old May 4, 2019 | 08:00 PM
projectSHO89
See owner's manual.
Old May 5, 2019 | 07:00 PM
alloro's Avatar
alloro
Originally Posted by Shakes88lb
sat for 5 yrs.
Gasoline breaks down after 2-years and won't burn especially after 5-years. You'll need to drain the tank and then add new gas.
Old May 6, 2019 | 06:19 AM
projectSHO89
"Bad gas" does not explain why he cannot connect to the PCM with a scan tool.
Old May 6, 2019 | 09:50 AM
alloro's Avatar
alloro
I know and you already covered that, so I was giving him the advice about the old gas because even if he followed your advice and got it to spark it still is unlikely to run on the old gas.
Old May 6, 2019 | 11:28 AM
projectSHO89
Even on "old" gas, it would likely sputter and at least try to fire. In any event, he has to get past an electrical circuit fault first.
I'd hazard a guess that a fuse or relay connection has either corroded or has expanded causing a lost connection or, perhaps, a critter got in there and ate some wiring.
icemaiden
Feb 12, 2014 09:25 AM
WBBulldogs
1997 - 2003 F150
Mar 4, 2013 07:25 PM
jpetty
1997 - 2003 F150
Oct 26, 2011 09:45 PM
beast2bessie
16
Nov 28, 2010 09:00 PM
ahawkfan1
1997 - 2003 F150
Jun 5, 2006 07:32 AM
