C6 auto shift linkage issues
Old May 6, 2019 | 09:37 AM
75f100hsv's Avatar
75f100hsv
Originally Posted by DB429SCJ
The manual control lever on E-Bay is marked D8TP-BA. Make sure you get the right one. 2WD & 4WD are different. 78-79 are different than 73-77.(grooves for nss). ND can give you the correct part #.
What is the board's thoughts on this adjustable shift assembly???
https://www.ebay.com/itm/Lokar-Adjus...4AAOSwxH1UD6Mj
Old May 6, 2019 | 01:49 PM
DB429SCJ's Avatar
DB429SCJ
It looks like it should work. The only problem with that setup is you cannot use the trans mounted nss. You will need to change the steering column to the earlier style with the nss on the column, or jump the nss connector in the harness. If you do that, the truck will start in gear.
Old Feb 22, 2026 | 07:42 PM
VM488W3's Avatar
VM488W3
Trailering
1978 Bronco C6 shift lever
I think the thread refers to the part I’m looking for. The lever arm is detached from the shaft, looks like it was sweated onto the shaft and has a number D8TP-BA stamped on the lever. Looking at the parts list it looks like 7A024 is what I’m needing. Can anyone please provide the actual part number needed to get a replacement if it’s still available? Or is there a good way to reattach the lever arm to the shaft, possibly HVAC compressor solder?
adebord
Sep 1, 2023 10:03 AM
jesse howell
Apr 7, 2020 05:34 PM
jniolon
15
Sep 3, 2019 08:11 AM
73 fourxfour
Feb 15, 2013 12:24 AM
