Stator Plug on Alternator
Old May 3, 2019 | 10:44 AM
zhicks16's Avatar
zhicks16
Forgive me... not trying to ask a really stupid question. I have a 1992 Ford F250 7.3 that I put an ambulance alternator on by accident (2 years ago, I just realized this) which causes my voltage to jump back and forth at higher amps than I am comfortable with. (Stupid question alert) Is it bad to run 100 amps vs the 60? I just purchased the 60 amp to see the difference but it does not have the external stator connection and so I am trying to figure out if I can still use the 60 amp or if it has to have that external plug? Sorry I have no idea what I am doing! I have a new voltage regulator on, and all grounds are good.
So essentially:
Problem - Wrong Alternator?
Solution: Use the 60 amp with no Stator plug?
Old May 3, 2019 | 10:49 AM
ford390gashog's Avatar
ford390gashog
The stator plug isn't used, I also clearly see the stator plug on the 60amp alternator. These trucks came with the large case 100amp alternator. I would not downgrade to a small case 60 amp. Your issue is probably a bad voltage regulator. Also the ambulance package vehicles came with a Leece Neville alternator and that isn't a Leece Neville.
Old May 3, 2019 | 12:00 PM
DarkOverCast's Avatar
DarkOverCast
When my stock 100A alternator failed, all the local store offered was a 70A and that wasn't enough to keep the batteries nice and hot.
My advice would be to ditch both alternators and do the 3g swap like I and many others have. You'll never be happier
Total cost of all my parts from a junkyard was sub $50
Old May 3, 2019 | 12:58 PM
zhicks16's Avatar
zhicks16
Thank you!!! I appreciate the help guys!
Bullitt390
May 16, 2017 05:32 PM
ramsay
Dec 31, 2010 05:33 AM
Blue86f150
Electrical Systems/Wiring
Apr 17, 2008 07:31 PM
Beast12
Feb 20, 2004 11:30 AM
bentkey
Mar 1, 2003 08:45 PM
