Question about the FAN
Old May 3, 2019 | 10:32 AM
pilgrimbizket's Avatar
pilgrimbizket
had the belt installed and with the belt holding the pulleys in place I can spin the fan freely to the left or right. Is this normal?
Old May 3, 2019 | 11:12 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
The clutched part will be free, but have some drag when healthy. When kaput, will just free spin.
If the nut spins, that is bad.
Old May 3, 2019 | 11:53 AM
pilgrimbizket
Thanks for the response brother.
The nut does not move and it has some resistance I was just able to freely spin the fan left or right and it never seemed to back up or down. Sounds like I am good to go!
Driving to up to Oregon tomorrow morning and just trying to dot my t's and cross my i's
Thanks once again.
Old May 3, 2019 | 04:19 PM
knottyrope's Avatar
knottyrope
many have removed the fan in texas for the extra HP and don't over heat
Mine has only kicked in a couple of times in traffic when towing.
Old May 3, 2019 | 08:07 PM
Hussler's Avatar
Hussler
Thanks once again.
Yes it's normal. Once the engine heats up, in hot weather and with the air conditioner on the fan clutch will start locking causing a bit of a roaring sound, usually in slower traffic. This is perfectly normal as the fan is just trying to pull more air through the front end.
Old May 4, 2019 | 12:19 PM
Hit Man X's Avatar
Hit Man X
I am in Texas and need the A/C most times due to humidity...so fan stays. 6.0 fan drops rotational weight and will free up some HP and TQ. Plus easier on the water pump too!
Long ago I saw dyno test with and without a plastic fan on the GMT800 trucks (yes, I own one!) Over an unlocked clutch, the power gains were about 6rwhp. Nothing much. Over a locked clutch it was 21rwhp!
I went from the steel one to HO plastic on my F150, it rev'd a tad easier but sure does cool better due to superior blade design.
Old May 4, 2019 | 06:42 PM
AK FORD GUY's Avatar
AK FORD GUY
On my last OBS Powerstroke, I removed the fan completely. Ran it that way for years up here in Alaska. Then sold the truck.
The temp gauge (although not a real reliable source) did not really change much at all.
I am considering removing the one on my current truck.
Old May 8, 2019 | 12:07 PM
DIYMechanic's Avatar
DIYMechanic
I ran mine a year or so without a fan as well. Only time it started to get hot was sitting in traffic in the summer heat. Aside from that, it was all good. I did put it back on, but they'll work fine without one for regular driving or in cooler climates. Not sure I'd want to be towing without one, though, especially in hot weather.
Old May 9, 2019 | 11:05 AM
dmd's Avatar
dmd
Towing here in Tx w/o a fan would get the trans pretty hot I would think. Be like going back to the stock cooler from the 6.0 cooler, trans would overheat very easily
in traffic.
Maybe go electric while in traffic would be a solution to removing the belt driven fan?
Old May 9, 2019 | 01:47 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Do most of you guys not have A/C? I understand our friends WAY up north, but it is almost always on in my vehicles to remove the damned humidity first, temperature control is just a bonus. No airflow over the condenser at 0mph will cause the high side switch to trip killing the system until pressure drops. Once moving, you are fine. Even 20mph has plenty of volume not to go too high.
Just do a 6.0 fan if you are concerned about that extra bit of power. Less rotational mass equal less power loss. Simple physics...like why trucks on Alcoas yield faster 0-60mph times and higher fuel economy numbers. I am doing a 6.0 fan when I find a deal on one, this metal one is hilariously heavy.
Old May 10, 2019 | 06:16 AM
DIYMechanic
I'm not saying everyone should run around without a fan, or that you should even try it if you live in Texas. If you read what I said above I clearly said it would "work fine for regular driving in cooler climates". I'd say that eliminates both towing, and Texas.
You really think you'll see a noticeable increase in MPG with Alcoas?
Old May 11, 2019 | 11:55 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Gotcha, must have missed it.
100% do on making economy go up if I swapped to Alcoas, or anyone else My steel wheels are ~40lbs each on the dually, plus about 45lbs per tire. I am going to run six, use some ratty ones for the inners. If I can even drop 15lbs/wheel that is 90lbs of tire weight gone.
My dead 6.4 I had since new came with a hair smaller than 35". Next set were 35" MTs. I wore them out, then to 35" AT. Truck was noticeably quicker, economy went up enough to measure. MT to AT was a drop in weight of about 17lbs/wheel as I recall on a SRW. You see also sports cars go from cast aluminum to forged aluminum. Stronger and lighter. Hell, all the over the road trucks I see here are on aluminum rims.
Old May 14, 2019 | 03:11 PM
knottyrope's Avatar
knottyrope
less rotational mass means better MPG
I hear it all the time on the Taco forums when they get bigger heavy tires and their MPG drops like crazy
Old Jun 22, 2019 | 11:32 AM
Airstreamer67's Avatar
Airstreamer67
I would think that any MPG improvement going from steel rims to lighter alloys would be nearly impossible to tell on our trucks. The improvement factor would relate to whatever the weight savings would be. So, say, a 9000 pound truck saving, say, 200 pounds due to lighter wheels would realize about a two percent weight savings. It would be like having an extra adult passenger or not. I doubt this could be measured in terms of mileage gain, especially if the truck is used mostly on the highway.
Now, lighter alloy wheels make more of a difference on a car, but in terms of improved handling due to less un-sprung weight. Sports cars can benefit significantly with better handling due to less un-sprung weight. Heavy duty trucks not so much.
Bigfront
17
Feb 23, 2022 08:01 PM
Necromancer
May 27, 2014 02:06 PM
TONKA05'
Jan 14, 2011 04:17 PM
badfl97
2004 - 2008 F150
Mar 21, 2010 12:03 AM
