Originally posted by crawlfish
Left valve cover decal : H J 4 2 8 A ... with punchouts for c21 which I presume to be mar 21.
49 State with Thermactor and A/C.
What's the calibration number?
Right valve cover decal states 351m/400 family with D7AE 9C 4 8 5
Ok, so it's an AE. Right below the Engine Family line there should be an Engine Displacement line.
Does it say automatic on the VECI? And if it does, what is the timing degree, the timing RPM and the spark plug type and gap? Oh, and the fast idle speed and cam?
ash
['I can crosscheck with the tuneup parametres.']
You can do a rough measurement through the spark plug hole. Just find something that will fit in and reach the bottom when the piston is at bdc. Then turn it over and measure how far it pushes it back out the hole. Something flexible like a piece of coathanger will do.
