2005 Excursion body mounts
Old Apr 28, 2019 | 01:04 PM
sgc2c's Avatar
sgc2c
I’ve got the 2005 v10 Eddie Bauer Excursion.
I need the body mount[s] for the front passenger
side. I cannot find part 2c7z-1000154-aa
anywhere (yes I know it isn’t made anymore).
NOS is almost nonexistent for that part.
Are any of the aftermarket body mount kits OK?
Dorman? Daystar?
I need the crunching noise when I come to a stop or
start from a traffic light GONE — it’s tearing into my
vey soul at this point. Any ideas you have are most
welcome because this is an otherwise good truck.
Kicks the crap out of anything GM builds.
Thank you.
Old Apr 28, 2019 | 01:36 PM
DavenTn's Avatar
DavenTn
Body mounts are like light bulbs.... one goes out but the others aren't far behind. Amazon has them
Old Apr 28, 2019 | 02:17 PM
sgc2c's Avatar
sgc2c
Which set do you recommend?
Old Apr 28, 2019 | 02:26 PM
DavenTn's Avatar
DavenTn
I don't know.... maybe someone who's needed them might chime in, but mine are still good. For me... I would avoid any that are stiffer than OEM unless you're off road a lot. Me, I tow a lot. OEM or similar are fine for me.
Old Apr 28, 2019 | 02:43 PM
sgc2c's Avatar
sgc2c
OEM is impossible to find.
Anyone recommend a good aftermarket set?
Old Apr 28, 2019 | 10:11 PM
EXSwap's Avatar
EXSwap
Choices are rubber or polyurethane. If mine need changed when I pull the body, this is likely what I’ll get.
https://www.energysuspensionparts.com/dfm001
Old Apr 28, 2019 | 10:35 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Mine definitely need changed. I should have done them when I had the interior out for soundproofing...dang it.
Old Apr 28, 2019 | 10:43 PM
sgc2c's Avatar
sgc2c
Thank you EXswap. — what is a rubber kit you’d recommend? I don’t want to increase NVH at all
and am interested in quietness, smooth ride and low
vibration.
Old Apr 28, 2019 | 10:46 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Here is a good video
Old Apr 28, 2019 | 11:06 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Old Apr 28, 2019 | 11:10 PM
sgc2c's Avatar
sgc2c
Nicmike I don’t think any of those fit the Excursion.
Old Apr 28, 2019 | 11:11 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Not sure why they wouldn't, but you could certainly be right.
Old Apr 29, 2019 | 07:02 AM
DavenTn's Avatar
DavenTn
Contact Tousley Ford... maybe they can help.
What ever you get, you will feel more energy transferred initially to the seat of your pants. The clunking will go away and the movement, but the higher density of new product will be noticable.
The most important thing to your ride is tires... assuming everything else is good.
Old Apr 29, 2019 | 11:40 AM
sgc2c's Avatar
sgc2c
Who knows of a rubber set of mounts that they trust?
As for tires: I’m using the Kelly Edge AT that the
Excursion came with. Decent amount of tread left.
Anyone like or dislike Kelly tires?
These are not especially quiet but good otherwise.
Old Apr 29, 2019 | 01:57 PM
EXSwap's Avatar
EXSwap
vibration.
My apologies, I was thinking the Daystars were rubber. They are in fact polyurethane.
I'd go with the energy suspension polys personally. I've used their parts and they seem to have a good compound on the poly.
I looked at White Bear Lake Ford's website and they don't carry them for the X. I also looked at the F250 parts for the same year and nothing.
