[QUOTE=Flyboy1100;18625016]It is real simple to unplug the sensors and clean the connectors though......not saying that’s necessarily your problem, but it was mine. 10min total, justonv
I have a question related to this, when your rear end went out and you mention the abs came on and stayed on did your speed still work, cause my rear end also went out and I put another rear end in mine and the abs light is on a solid but my speed is still actuate, I only wish and hope it’s just the sensor in the rear end having to be replaced, I’m going to get another one to try it and hopefully that’s the problem
Reason: Tagging the person for this notification
Thank you for the tip. I will take a look at that today. I am still going to get a ForScan setup but need to get my ducks in a row first.
Originally Posted by justonv
Mine has had ABS light come on twice since I got it in 2014, both times it came from the speed sensor on the rear differential. First time I believe it was damaged when my pinion bearing went out, had a light after I rebuilt until I finally remembered to order a new sensor. Second time was recently, drove it that way a few months, happened to notice the sensor and surrounding area was oily while I was checking oil in the diff before a trip. Tried to clean the sensor and plug, worked for a while, but the o ring was damaged, so it got oily again. Replaced sensor again because I couldn't find an o ring that fit right, and sensor was only 14 bucks. No more ABS light for at least 3 months now. Might be worth a shot to at least check your sensor, clean it up a little.
justonv I have a question related to this, when your rear end went out and you mention the abs came on and stayed on did your speed still work, cause my rear end also went out and I put another rear end in mine and the abs light is on a solid but my speed is still actuate, I only wish and hope it’s just the sensor in the rear end having to be replaced, I’m going to get another one to try it and hopefully that’s the problem
