Sponsored by: Auxito
'91 AOD swap
Old Apr 25, 2019 | 04:55 PM
RacerJames's Avatar
RacerJames
'91 AOD swap
I have a '99 F-150 with the 4.2L and the 4R70W trans has stopped working. I have a good '91 AOD. What are the issues I can expect if I install the AOD?
Old Apr 25, 2019 | 05:39 PM
Bluegrass 7's Avatar
Bluegrass 7
You can't. Nothing will fit a 4.6/5.4.
1. The bell housing will not bolt up.
2. It is not an electric controlled transmission.
.It may be called a 4R70 but the old version before electric control, hence the name AOD.
AOD is throttle pump pressure control and manual kick down.
None of these operations are used after 1997, not even on the V6.
Old Apr 25, 2019 | 06:20 PM
Conanski's Avatar
Conanski
Is the trans totally slipping? If you have hard/late shifts the trans isn't done you have sensor or wiring issues.
The AOD will bolt to the 4.2L V6 but it's an uphill battle after that because of the PCM that is expecting to see computer controlled trans.
F100Gasser
May 3, 2017 06:49 PM
wozxxx86
Dec 28, 2006 06:22 PM
aayoakam
May 24, 2006 01:36 PM
rdy
Oct 13, 2004 01:26 PM
92AeroStarXL
Aerostar
Dec 15, 2003 01:11 PM
