I’m back
if your going to change the suspension why not go with a setup that eliminate the rear block, has the correct spring rates and doesn’t require a rear sway bar or anti wrap bar ? Plus it rides and handle better since the shocks actually match the spring rates, oh and it cost a fair bit less then the old X/mod setup. Just sayin...
what happened was all these years I have been on FTE and I didn't realize people were paying silly money for the old ju k yard fix which back in the day worked ok but mainly because it was the only option available back then (early 2000's) and it was out of the junk yard so it was super cheap, Since realizing this I have spent a fair amount of time sorting out many old setups and letting people know of a better option that has been around for quite some time but apparently hadn't become popular on FTE but is certainly well proven elsewhere.
fwiw, the front 2* shims are optional but set the front caster to 5.5* which will give a slightly heavy feel to the steering but not only cures wander it provides a rock solid straight as an arrow highway tracking. the 2* rear shim is to correct driveline angles if you have a single joint each end driveshaft.
and for the first time in public I will share a secret, the Bilstein 5100 are decent but pretty far from excellent, to that end I am working with the top shock tune guy in the country and Fox shocks to make a Excursion Fox IFP shock available that. ( I have been working on this for a year now and have a version of them on mine)
I have provided links to all the parts you need and narrowed it down to 2 vendors. ( shocks will likely be a 3rd vendor when they are ready )
Total cost $1074 complete
Front Procomp leaf springs 22210 $90 each
Rear Procomp Leaf 22415 $106 each
Zone adjustable Track Bar $100
Bilsteins 5100 shocks
Front $180 pair
Rear $156
Ubolts
Front $54
https://www.wfoconcepts.com/pr/Front...ts/19732/16883
Rear 8’’Ubolts x 3.5” round $47
https://www.wfoconcepts.com/pr/WFO-I...ts/19732/16924
3’ Spring Plate rear $38 pair
https://www.wfoconcepts.com/pr/3-Lea...rd/16828/17035
Front 3’ wide 2* shim $35 pair
Rear 3” wide 2* shim $35 pair
https://www.wfoconcepts.com/cr/3-Inch-Axle-Shims/4384
Ride height with this setup as measured from the center of the hub straight up to the bottom of the fender arch is 27". with an air bag setup recommended for level towing if you have more then 800-900lbs tongue weight, You can lower the ride height to 25" front and 26" rear ( stock is 23" front 24' rear ) requires air bags for any towing more then a tent trailer or so..
Front $180 pair
Rear $156
Ubolts
Front $54
https://www.amazon.com/Explorer-Pro-.../dp/B000CNBQ12
https://www.amazon.com/Pro-Comp-2241.../dp/B001FBMKF6
https://www.amazon.com/Zone-Offroad-.../dp/B0025ZMFJC
Front $180 pair
https://www.amazon.com/Bilstein-3318.../dp/B00DRYS0GW
Rear $156
https://www.amazon.com/Bilstein-33-2.../dp/B00IL8BN0E
Ubolts
Front $54
https://www.wfoconcepts.com/<acronym title="Page Ranking">pr</acronym>/Front-U-Bolt-Kits/19732/16883
https://www.wfoconcepts.com/<acronym title="Page Ranking">pr</acronym>/WFO-Individual-U-Bolt-Kits/19732/16924
https://www.wfoconcepts.com/<acronym title="Page Ranking">pr</acronym>/3-Leaf-Spring-Plate-Ford/16828/17035
truth be told, the cost savings is the least cool thing about it, the performance you get every time you drive your Ex is the best part.
Do you do any heavy towing ?
my next project is building a air bag setup specifically for this application (if all goes well WFO will be the vendor as I am not in the parts biz, I just want Bitchen stuff for my Ex and with my connections in the industry if I make 1 I can just as easily have them available to my fellow Ex enthusiast
How would you lower your recommended setup down to 25" & 26" from the 27" all around? Not that I would, just curious about the how.
new spring plates are not required if yours are not bent but I have seen enough that are that I just suggest replacing them from the get go. If yours are not bent then use them.
lowering the 22210/22415 combo
it is as easy as removing the bottom leaf from each pack that is the HOW
disclaimer I have not done it personally and you know how I hate discussing or at least recommending things that I do not have personal experience with. the measurements are hers and I followed up with her years after she did it to verify how it was doing.
going to help a friend do his “Camo suspension” and when we do I will at least measure the bottom leafs to calculate the spring rate with them removed. However I have built enough spring packs to feel OK discussing the mod.
The WHY is simple enough, the weight of the excursion compresses the lower spring rate more. Simple enough.
lets see if we can fix that without going to a whole new suspension.
Can't wait for the results. It's always good to have options for these beasts, whether it's WE3ZS Modded X/B's, Carry's suspension setup from CT Performance, the various setups our vendor Junior at ATS sells, or the setup you're putting together.
Stewart
