Sponsored by: Real Truck
Going nuts electrically...
Old Apr 23, 2019 | 09:51 AM
Txgr8white's Avatar
Txgr8white
My 2001 F250 with the 7.3 is having some issues with the windows, wipers, etc not functioning when I twist the key to ACC. If I start the truck, these items still will not operate for the first minute or two. Is this a faulty GEM? I have checked the Delay Relays and swapping them out does not help.
Thanks in advance.
Old Apr 23, 2019 | 10:29 AM
alloro's Avatar
alloro
Either you or a helper hold a finger on the delay relay while the key is turned to the ACC position. If the relay is energized with a delay it's probably the GEM. If the relay clicks right away then it's probably an issue with the circuit that passes through the relay contacts.
Old Apr 23, 2019 | 01:29 PM
wizkid00104's Avatar
wizkid00104
There is a relay on the gauge assembly that wears out. I am having the problem too. See here: https://circuitboardmedics.com/ford-...luster-repair/
Old Apr 23, 2019 | 02:55 PM
Txgr8white's Avatar
Txgr8white
Do you have any other info besides someone that does cluster repair? I repair some of my own BMW modules, so changing out a relay on a PCB is not a problem.
Thanks
Old Apr 23, 2019 | 03:16 PM
projectSHO89's Avatar
projectSHO89
Your experience with the 02 does not apply to the OP's 01. The electrical systems are different. On an 01, the Battery Saver relay is in the GEM module.
Old Apr 23, 2019 | 08:20 PM
wizkid00104
My bad, I thought they were the same.
I did do some research. I am an electrical engineer and I wanted to find a way to do it myself. I could not find a direct fit relay or socket from the pictures I found, but I think you could easily solder on some leads and connect a generic SPST relay. Here is the note I made when I was researching it: https://www.ford-trucks.com/forums/1...l#post18231110
Old Apr 24, 2019 | 06:52 AM
projectSHO89
Nah, they did a semi-major change in the Super Duty electrical systems from the 99-01 vs. 02-04 models. The GEM went away in 02 and the functions it handled were moved elsewhere.
Just as a note, the relay in the cluster is not the "Accessory Delay" relay, it's the "Battery Saver" relay which controls the accessory delay relay which is still located in the CJB.
Old Apr 24, 2019 | 09:11 AM
wizkid00104
Good to know. Thank you!
Medic13
Electrical Systems/Wiring
19
Aug 8, 2013 03:38 PM
stroke-of-luck00
Oct 31, 2008 09:16 PM
mlkull
1983 - 2012 Ranger & B-Series
Jan 15, 2003 07:43 PM
