ISSUES!!!! Need help
Old Apr 22, 2019 | 08:15 PM
Texascowboy77's Avatar
Texascowboy77
Ok guys I have a 78 F-150 4x4 with a 351m and C6 auto. Driving home today I was running 60 no problems when she just fell on her face. Slowed down and shifted into 2nd and it picked up and went on. Got back up to speed and down she goes again and does before I could get it to the side of the rode. When it lost power I would press the gas and it would bog down like it was choking. I’m thinking something in the carb broke cause I tore it apart and it was nasty. Need some advice on how to proceed. Thanks in advance
Old Apr 22, 2019 | 08:17 PM
fordguy76's Avatar
fordguy76
Either the fuel system or jumped time. Could be dirt in the gas anywhere.
Did it start back up?
After the initial issue did it seem to run right after you got back up to speed? Or did it run bad again?
If the carb is nasty, do a rebuild and hope that fixes it.
Old Apr 22, 2019 | 09:06 PM
mark a.'s Avatar
mark a.
Check dizzy roll pin.
Old Apr 22, 2019 | 09:07 PM
Texascowboy77
No it didn’t start back up seemed like it was getting fuel but after the initial incident it ran fine until it did it again and died
Old Apr 23, 2019 | 06:27 AM
meangreen92's Avatar
meangreen92
Check your PCV valve to make sure it's not coming apart.
I had one in an '82 Mustang GT where the plastic body of the PCV degraded enough to let the inner valve piece drop down too far sometimes, creating a pretty bad intermittent vacuum leak, and hence causing an intermittent driveability and idle problem which it took me months to find...
BrownBrutus
Jun 17, 2012 09:05 PM
CJPA
Sep 25, 2011 11:04 AM
the78ranger
Mar 17, 2011 07:35 PM
Grannygear
Mar 26, 2008 06:46 PM
Josh79
Feb 14, 2008 04:08 AM
