Bent hitch Pin
Old Apr 22, 2019 | 10:50 AM
mojavearcher's Avatar
mojavearcher
Bent hitch Pin
I tow a bumper pull trailer that empty is 7400 lbs but using the 3 inch receiver and a weight distributing hitch it always bends the hitch pin. Just enough that it gets hard to take out and reinstall. Any one else have this problem and whats the cure ?
Old Apr 22, 2019 | 11:42 AM
landman873's Avatar
landman873
I'd almost think something is causing you issues somewhere else. I've never bent a hitch pin on any of the trucks or equipment I've ever had. Normally the hole get egged shaped before anything else.
Old Apr 22, 2019 | 12:17 PM
speakerfritz's Avatar
speakerfritz
Are you using a collar to reduce the 3” to 2.5” ?
Old Apr 22, 2019 | 01:20 PM
wrvond's Avatar
wrvond
I bent a couple of those Reese brand locking hitch pins. Replaced them with a Bolt locking hitch pin which hasn’t bent but did start “ovalling” the pin hole in the receiver using a 2.5” drawbar with the 2.5” sleeve. The solution was to weld the 2.5” reducer into the 3” receiver. This has completely eliminated all slop and stopped the damage.
The fact is, I seriously doubt I’ll ever have any hitch with a 3” shaft.
Old Apr 22, 2019 | 02:07 PM
speakerfritz
this will reduce the max of the 3” at 21k to a much lower number....may not be a big deal.
Old Apr 22, 2019 | 05:45 PM
mojavearcher
No not using the collar. Using a 3 inch receiver . I welded 1/4 plate stock to the outside of the receiver with 5/8 holes that match stock holes perfect to keep it from making stock holes oblong like it has done on my past two trucks. Went to buy a new pin today and every one I looked at have made it China on it. Maybe that has something to do with it. I will look into getting a Hardened 5/8 bolt.
Old Apr 22, 2019 | 05:50 PM
SESWIM's Avatar
SESWIM
Get one from the dealer.
Sam
Old Apr 22, 2019 | 08:07 PM
HRTKD's Avatar
HRTKD
My dealer supplied pin is still straight. I've used it with my 3" Weigh Safe ball mount, 3" Andersen WDH Shank and my 2" Blue Ox WDH shank (using both reducers). The receiver hitch itself is getting oblong holes where the pin inserts into.
Old Apr 23, 2019 | 09:47 AM
wrvond's Avatar
wrvond
Thought about that, but don’t agree running a bead around the outside lip where the two make contact will reduce load bearing capacity any more than inserting shims to stop movement.
I ran a rigging and weight test shop in the Navy and never saw a load test fail at the weld, either.
Old Apr 23, 2019 | 11:53 AM
delorenzomp's Avatar
delorenzomp
Maybe look into what B&W offers made in USA...
woodsd79
Jul 14, 2020 05:10 PM
CarterKraft
Jun 10, 2018 11:31 PM
Boomer23059
All Things Towing
17
Aug 2, 2011 06:06 PM
BlueOvalBud
18
Dec 16, 2010 06:38 AM
rambuck
13
Feb 13, 2009 10:32 AM
